sbc help
Old 10-20-2011, 10:00 AM
gnos454
Default sbc help
sbc stroker , punched out 60 over , dart alu. heads, super vickter intake, just replaced head gaskets and intake gaskets (felpro) permatexed around water jackets on the intake and i'm still detting water in the oil , not as bad as before but bad enough,,,,
gnos454 is offline
Old 10-20-2011, 10:17 AM
fast75vega
Default Re: sbc help
stock block? 60 over is pretty thin.......crack in the cylinder wall?
check the plugs to see if you have one that is really wet :wink:
fast75vega is offline
Old 10-20-2011, 10:23 AM
itsabird
Could have gotten into water passage, when clearing the block for bigger stroke crank.
itsabird is offline
Old 10-20-2011, 11:01 AM
gnos454
Default sbc
yea just pulled all the plugs and spun the motor, stot water out of # five ,,,,,,,,,,cracked block ,,,,,bummer ,,,,, but got a spare block,,,
gnos454 is offline
Old 10-20-2011, 11:49 AM
fast75vega
Default Re: sbc
i would never go 60 over on a stock block.... unless its the old heavy duty nickle truck block :wink:
Old 10-20-2011, 01:58 PM
gnos454
yea i hear ya , think i might keep the spare block @ 30 over and buy new pistons ,,,,,,
gnos454 is offline
Old 10-20-2011, 04:46 PM
  #7
bbchevy
Default .060
You have NOTHING to worry about @ +.060 on a 350 Block,thats Only 4.060.A Stock 400 is 4.125.
Must have Ran a Couple DOZEN back in the 70's @ +.060!!!Never had a Problem,Until the 400 JUNK Came along,...............>
You say its a Stroker,....?How much Stroke do you have?
Later
G 8)
bbchevy is offline
Old 10-21-2011, 04:06 AM
  #8
fast75vega
Default Re: .060
Later
G 8)
the only way i seen anyone get lucky with a 60 over block and not have the block cracking or running hot issues is when they used the HD chevy nickle block...... other then that i myself would only use a 60 std block for an everyday... go to work and home.... driver only :wink: 60 is just a waste of money in my honest opinion :roll:
Old 10-21-2011, 04:08 AM
  #9
outlaw256
aint nothing wrong with a 60 over 350. built many of them and run quite a few hard at the track. never had a minutes problem.
outlaw256 is offline
