Bbc hp est
Old 09-23-2012, 04:23 PM
ejm
SENIOR BUILDER
Default Bbc hp est
454 .040 over kb hyp pistons 11:1 Chevy 781 heads 2.19 in 1.72 ex bowls blended 629 lift solid flat tappet cam eagle forged crank stock rods all balanced Holley single plane intake and a demon 850
ejm is offline
Old 09-23-2012, 05:35 PM
fast75vega
im gonna say 550-600ish
fast75vega is offline
Old 09-26-2012, 07:07 PM
maxpower671
SENIOR BUILDER
Default Re: Bbc hp est
-what's rest of the cam specs? duration, lobe sep?
maxpower671 is offline
Old 09-27-2012, 01:45 PM
ejm
SENIOR BUILDER
duration 306 @.050 260 lobe sep 110*
ejm is offline
Old 09-27-2012, 02:04 PM
bixblk
bixblk's Avatar
Default bbc hp estimate
I had a similar (but a stroker) set up, slightly less cam (both lift and duration), 489 inches
(4.25 stroke .030)with a 1050 dominator made 578 hp with a very nice flat torgue curve. It was a roller cam and rect port GM heads, and 10.4 to 1 compression.
good luck !
My guess is 540 ish
bixblk is offline
Old 09-28-2012, 06:20 AM
roadkill2
It don't matter! You really don't care . .
"Horsepower" is one of two things. A measurement determined by testing the actual output with a Dynometer, or a term used at the Bar when trying to impress people who don't know any better . .
If you're a racer (or engine Builder) and build an engine for a specific purpose (Like Quarter Mile Drag racing, for lack of a better one) then ET is (or should be) your primary concern.
Doesn't matter whether you're racing heads up or Brackets, it's ET or the potential to get to that ET that you're concerned with . .
And, based upon both experience of yourself, or those who are relatively successful at the type of racing you're doing, ascertaining the build and it's potential results should be, literally, empirical . . .
The "Fine Tuning" for good results and engine longevity belong to the user . . . and still have little to do with the spoken word "Horsepower" . . .
Jus' sayin'
roadkill2 is offline
Old 09-28-2012, 09:01 AM
  #7
maxpower671
SENIOR BUILDER
Jus' sayin'
x2! very true. build an efficient, reliable engine for your application and let the HP number fall where it falls
Old 09-28-2012, 09:14 AM
  #8
fast75vega
Jus' sayin'
i think differently ... no self respecting car nut is gonna be ok with saying... well its 300hp but it runs consistent.... lol I'll take the ponies and tune it to be consistent :wink:
Old 09-28-2012, 02:17 PM
  #9
ejm
SENIOR BUILDER
Well it's not a drag motor and will never be consistant, its in a pulling truck and every track is different and the sled can be weighted differently as can the gearing it the weight box. So i was just asking to have a clue where i stand withe the other 600-625hp trucks out there. Sorry if this thread bothers some of you.
ejm is offline
Old 09-28-2012, 03:45 PM
  #10
BEAST477
BEAST477's Avatar
Are you in a class that limits what head or camshaft you can run?
BEAST477 is offline
