fuel pump gph
Old 04-16-2012, 05:10 PM
hotrod1994
Default fuel pump gph
hey guys i have a mild 350
9.5:1
477/477 lift 268/268 duration cam
stock heads milled to get 9.5:1
Holley 600
edelbrok torker intake
what gallons per hour at what psi should i run?
im looking for mechanical fuel pump that dosen't need a regulator at a good price so what kind of gallons per hour at what psi should i look for
thanks guys
hotrod1994 is offline
Old 04-16-2012, 11:12 PM
bluedawg357
CRAFTSMAN
I'm running a 110 gph on my 400 sbc, and ran the stock gm on my 350 with a slightly larger cam with edelbrock heads, so I would say a stock gm would work just fine. Just my .02$
bluedawg357 is offline
Old 04-17-2012, 10:02 AM
hotrod1994
ok i was thinking of running one that was equivalent to a more performance sbc from the early 70's the motor is in a 76 camaro
Old 05-25-2012, 06:28 AM
Notalent
You can get away with an 80GPH or 110GPH and have it set at about 5.5 PSI. The Holley 12-834 or 12-327-11 will be a great option and wont break the bank and no need for a regulator, but it IS suggested...you want to know whats going on and just because these pumps come preset, does not mean they are putting out that much PSI. It could be more or less.
Notalent is offline
