HP EST AND 1/4 MILE TIME EST
Old 06-25-2011, 06:42 PM
hotrod1994
Default HP EST AND 1/4 MILE TIME EST
sbc 350 stock bottom end 10:1 compression with
aluminum angle plug heads ebay heads
intake Port Volume 210cc
Intake Valve Size 2.02
Exhaust Valve Size 1.60
lunati 60105 cam
Advertised Duration : 284 /292
Duration @ .050 IN/EX : 241 /249
Gross Valve lift IN/EX .525''/.546''
LSA and ICL 110/106
RPM Range: 2500-6600
High Rise Aluminum Intake ebay intake
single palne 2500 -7500 rpm rang
holley 750
Mallory hy fire 6 and Mallory unilight distridutor with msd blaster coil
th350 stage 2 shift kit 2200 stall 4:10 gears and 29x12.50 m/t sportsman pro
hotrod1994 is offline
Old 06-25-2011, 06:54 PM
MEMRACING62
mid 300's....carb is to big ....with that stall & carb you are not going to be happy
MEMRACING62 is offline
Old 06-25-2011, 07:01 PM
fast75vega
im gonna go with around 375hp and low 12's in the 1/4
fast75vega is offline
Old 07-02-2011, 10:21 PM
bixblk
bixblk's Avatar
Default hp ?
360 HP
I agree with the stall speed being too low, 3500 would be better, put a small NOS kit on this set up, they seem to wake up this combo.
750 carb have alot of range but it maybe a bit too big w/o spray
bixblk is offline
Old 07-08-2011, 09:09 AM
JEFF69Z28
Default Re: HP EST AND 1/4 MILE TIME EST
lunati 60105 cam
LSA and ICL 110/106
holley 750
WHAT DOES THE VEHICLE WEIGH
JEFF69Z28 is offline
Old 07-11-2011, 09:56 PM
hotrod1994
its a stock body 76 camaro around 3500
