BRAKE LINES
Old 06-22-2011, 02:37 AM
JEFF69Z28
Default BRAKE LINES
can you run braided line from the master cylinder or do they have to be steel?
JEFF69Z28 is offline
Old 06-22-2011, 05:38 AM
oldandtired
oldandtired's Avatar
Braded is OK, after all that's what you run to the front calipers.
oldandtired is offline
Old 07-14-2011, 12:21 PM
wardy
Default Re: BRAKE LINES
I would use a hard line from the master cylinder, then braided line out to the caliper (from the frame). Too much braided line is a bad thing.......
wardy is offline
Old 03-04-2012, 03:40 AM
fmfire672
Jeff Too much braided line will cause a spongy pedal. Stay with as much hard line as you can
fmfire672 is offline
Old 03-04-2012, 07:35 AM
TheYellaBrick
TheYellaBrick's Avatar
X2 Use the hardline as far as practical but use enough braided to ensure enough slack between frame and caliper to prevent strain and or tire/chassis rubbing.
TheYellaBrick is offline
Old 03-04-2012, 08:38 PM
olds48
Hard line is cheaper,lighter and longer lasting. The flexible parts are just necessary evils.
olds48 is offline
