Darts left when I lift
Old 11-22-2010, 08:09 AM
jglennfillmore
Default Darts left when I lift
The car has some pull to the right under acceleration and then darts left when I lift. The car is a 2500 super gas strut front end and four link rear. The front end was just lined up so I'm thinking maybe something in rear. Nothing appears to be broken or bent. This is a new car to me.
jglennfillmore is offline
Old 11-22-2010, 09:16 AM
ajk
Look for posts by jreiley he had a similar problem not to long ago. maybe some of the responces he got may help you. AL...
ajk is offline
Old 11-22-2010, 06:54 PM
TheYellaBrick
TheYellaBrick's Avatar
Have you checked the chassis square ?
Is the rear end square with the chassis/front axle line ?
Sounds like it could be the right side wheelbase is a tad longer than the left.
TheYellaBrick is offline
Old 12-07-2010, 05:12 PM
coolracing
Does the car have a anti roll bar?
coolracing is offline
Old 12-08-2010, 01:32 PM
TheRabbit
TheRabbit's Avatar
Default Re: Darts left when I lift
Lets start from scratch. You said the car was new to you. Did someone have it before you or did you build it? If someone else had it did it drive straight? What have you done to it since you've had it?
May sound crazy, but if something changes always think back to where the problem started.
TheRabbit is offline
Old 12-08-2010, 02:16 PM
gearhead1011
gearhead1011's Avatar
Check the bump steer.
gearhead1011 is offline
Old 12-08-2010, 05:36 PM
  #7
coolracing
X2 J.A.
Old 12-08-2010, 05:46 PM
  #8
TS1955
Put the car on a set of scales. Check and see how much pre-load is in the chassis.
TS1955
TS1955 is offline
Old 12-08-2010, 06:49 PM
  #9
jed5161
CRAFTSMAN
had a super gas camaro doing simular thing....finally got to the point where it was swaying all the way down the track. Tore all the rear end suspension apart and found panhard tube bending under load and all heim ends were .002-.004 loose. replaced all ends and converted panhard rod into the newer style x-link setup and was fine after that.
jed5161 is offline
