Q16 racing fuel
Old 07-26-2010, 03:07 PM
nova69jml
Default Q16 racing fuel
Can anyone tell me the pros and cons of Q16 fuel, who's using it, I don't mind the cost if it works, does the engine run any cooler? ect.
nova69jml is offline
Old 07-26-2010, 03:12 PM
TheRabbit
TheRabbit's Avatar
Not being rude, but you may want to search a topic before you post a new thread.
http://forums.racingjunk.com/viewtop...&highlight=q16
TheRabbit is offline
Old 11-14-2010, 11:48 PM
ShirleyPillsbury
i heard that Q16 is good about "cont" don't know but I'll ask my friend to tell you about it!!
ShirleyPillsbury is offline
Old 11-22-2010, 06:35 PM
cncmotorsports
Default Re: Q16 racing fuel
We use a ton of VP113 which is a lower octane. Yes the engines will run cooler. You will need to jet up and take out timing. If your not using it now, I do recommend dynoing your engine for maximum performance. Its great fuel.
cncmotorsports is offline
Old 11-23-2010, 08:53 AM
TheRabbit
TheRabbit's Avatar
How much timming you take out? I switched from C16 to Q16 2 years ago and I didn't take any timming out or notice any temp change. Not saying it want run cooler after long periods of running. I don't run my motor very long at a time, but see no difference from what it use to be.
Old 11-24-2010, 07:04 AM
cncmotorsports
depends on the combustion chamber volume, typically 2 degrees on some engines. You will also need to jet up the carb, they like more fuel.
Old 11-24-2010, 07:46 AM
  #7
TheRabbit
TheRabbit's Avatar
I uped mine 5 jets and had to change the air bleeds too.
