rear end swap
Old 04-05-2010, 07:46 AM
irishfanwsp74
Default rear end swap
o.k. I have a 1991 older body style suburban that the rear-end needs re-built but I don't have the money to re-build it at this time,so can I swap a rear-end out of my 1989 chevy blazer 4x4 to the 91'chevy suburban?
irishfanwsp74 is offline
Old 04-05-2010, 10:14 AM
signsbyesa
first off ou did not mention if they are 12bolts, im sure they did
not put a 10bolt in a suburban or a 4x4, 12 bolts are interchangable,
but you will need only gaskets if your bearings are good, your
yokes should match up and should not have a problem, but, i would
search on internet on both vehicles and get all the info on the
rears and drive shaft length and your splines match, your gear
ratios might be different as well, do the research
signsbyesa is offline
Old 04-05-2010, 12:32 PM
irishfanwsp74
Default thanks
they are 12 bolt.and thanks for the info I'll do more research.
