still using solids
What do you guy's think about using a comp cams solid lifter cam. spec's: int..555/exh..555 110 lobe sep. installed in a 377 chvy w/ dart iron head's 64 chambers, 215 port's w/ 2.05 int. valve's. car weigh's 1700lbs. Kris
The car is an Altered w, 32 Bantam body. 377ci w/ .225th dome's. I run this car in a nostalgia class. Was actually thinking about running a little more lift due to the head's I am using. The car w/ a 5.14 gear run's low 6.20's off the handbrake in the 1/8th. I was thinking of moving up around .580-.590ish. I can do this safely. What do you think as far as a roller goe's would be a good choice w/ these head's? Kris
#7
I ran this cam for a couple yrs. it worked great in a heavy car, lot's of low end and up too 7200rpm. Don't know how good it would be in a light car though. I spent close to $800.00 went roller and picked up less than a tenth with a .626 roller. Just keep the springs around 140lbs seat pressure and i agree with sg1586
on the pressure oiled solid lifters.
