Federal-Mogul lightweight pistons questions and specs
Old 09-25-2008, 03:39 PM
hammerdamage
Default Federal-Mogul lightweight pistons questions and specs
hello all, i have a nos set of discontinued lightweight federal mogul pistons with the part numbers of lw5020f and lw5021f. they are small block chevy pistons for a 383 stroker . i have little info other than the weight (448 grams), compression ( 10.5-1) and that they are 2618 alloy. if someone has an an old F-M catalog i could use some info like valve relief cc's,piston to cylinder clearance, compression height etc. i am building a new motor for next season and could use the info. thanks in advance for any info. gary
hammerdamage is offline
Old 09-26-2008, 04:20 AM
sg1586
Post that info on ST if no one can help you here..
sg1586 is offline
