What would you give ?
I've been looking around here and there for a 454 block, 2 bolt or 4 bolt virgin to 60 over. I've found some good deals and they are gone when I get there the other ones I find seem to be more $ then I think they are worth, what do you guys think a 454 block is worth now days ?
I been looking to spend 250-300 for a 2bolt and 350-400 for 4 bolt, a year ago I found several this year nothing when I want it. am I being to cheap or are they just wanting to much ?
#7
JUNIOR BUILDER
I got 3 short deck blocks for ya. 1 is a 100% virgin 1973 and the other is .030 and main studded. 500$ each. OR, got a bowtie block that is 4.600 needs to go to 4.630. that 1 is 700$ or cheaper it has a small battle wound which has been repaired. If you are interested give a call at 320-296-6365c all prices can change to got get ride of them. all 3 are Shortdecks...
Brian
also have a short deck 4 bolt block that is .060. rehone and that will cleanup nice.
so a total of 4 blocks for ya
Brian
#8
I finally came up a little on what I wanted to give and think I got a good deal from a local machine shop I use. 454 4 bolt block, bored 60 over just need finish honed. Has new cam bearing,freeze plugs and arp main cap bolts. Picked it up for $550.00 and saves me all the machine work
#10
Brian
Brian
