what if i dont have the right stall converter?
Old 09-23-2007, 04:17 PM
Blue68Camaro
JUNIOR BUILDER
Default what if i dont have the right stall converter?
My cam specs recomend a 3000 stall. But as far as i know mine is just a 2000. What kind of problems will i encounter. Just a lack of power on the lower end?
Blue68Camaro is offline
Old 09-23-2007, 04:31 PM
woodsman
Blue68Camaro your car just want run at its best if you don't have the right converter.
woodsman is offline
Old 09-23-2007, 04:34 PM
Blue68Camaro
JUNIOR BUILDER
What do you mean "run" can you explain?
Old 09-23-2007, 04:56 PM
woodsman
If you load your engine up at 2000rpm and your cam wants 3000rpm than you will not get your best ET because you are operating outside of your cam spec. Its not going to hurt anything but your ET an MPH. If you put a 3500 stall in it you will see what I mean right off. We'll have fun with it.
woodsman is offline
Old 09-23-2007, 05:13 PM
Blue68Camaro
JUNIOR BUILDER
OK so it only really matters for the strip. As far as driving on the street maybe just a dog on the low end?
Old 09-23-2007, 05:20 PM
woodsman
You got it
woodsman is offline
Old 09-23-2007, 06:31 PM
  #7
knova70
SENIOR BUILDER
car might jerk when stopped at a light or whatever,to low of a stall speed and the car wont idle without holding the throttle.
knova70 is offline
Old 10-17-2007, 08:32 AM
  #8
dgrobels
itll be a real dogg with a big cam and small converter dont mix
ask me ho w i know
learned this when i was 18 put a 240 240 530 540 cam in a bb olds 455 with a stock converter it wouldnt even burn the tires
you need a 3000 for any muscale car in my opinion
dgrobels is offline
Old 10-17-2007, 09:56 AM
  #9
chevguy65
Not only will it not want to idle in gear, it will be a bitch to hold back.
I made that mistake once and my leg got really big holding the car at stoplights.
chevguy65 is offline
