Attention Vegaswheelsup!!!
Old 08-31-2009, 08:31 PM
  #51
mopar1968
mopar1968's Avatar
LOL How you doing ol'e buddy, been working in my shop some at night, also building my street engine,
mopar1968 is offline
Old 08-31-2009, 08:37 PM
  #52
chrisr
good to hear you have been getting out in the shop, any racing any time soon?
chrisr is offline
Old 08-31-2009, 08:41 PM
  #53
mopar1968
mopar1968's Avatar
I have been for about three month's now, won one, runnerup in a heads up race, two semi's. things going good for you?
''JUST MY TWO CENT'S WORTH''
Old 08-31-2009, 08:47 PM
  #54
chrisr
I have about 25 passes on the car now. I was adding some pinion angle and found one of my coilovers had come apart, the bottom housing dropped off the shaft when I took it loose from the mount. I also pulled my intake to do some port work and found it was not sitting down on the motor enough so it is at the shop getting cut down. I should be back out in a couple weeks.
chrisr is offline
Old 08-31-2009, 08:50 PM
  #55
mopar1968
mopar1968's Avatar
Yeah i am having hooking problems also, working it out, tires still spinning 1 complete turn before launching. thinking about adjusting ladderbar's don't know which way i should go? They are netural right now.
Old 08-31-2009, 08:59 PM
  #56
DirkaDirka
DirkaDirka's Avatar
Originally Posted by chrisr
Hey dirka, you have to ignore Mopar, he fell off the bus once and hasn't been the same since. He actually likes Mopars eversince the accident also.
Just messing with you Mark.
Is that a camaro in that pic??
DirkaDirka is offline
Old 08-31-2009, 09:05 PM
  #57
chrisr
I wasn't having problems hooking, I set mine up with only about 1/2 a degree of pinion angle so that if it wanted to go left or right I would still have the front end on the ground. Now that I know it launches straight I put 2 degrees more in it to put some lift on the front. It was coming out of the hole flat but still cutting 1.37 to 1.40 60's. I am getting ready to spray it so I figured I better adjust it some to put a little weight back there. I did the same thing with my last car and everyone said it wouldn't make a difference but it went from coming out with the front flat cutting 1.47to 1.50 60's to pulling the front about 3inches and carrying it out and laying down real smooth cutting 1.35 to 1.37 60's.
chrisr is offline
Old 08-31-2009, 09:06 PM
  #58
chrisr
Yea, don't hate me cause I am a Chevy guy. I like any old car fixed up or made to go fast.
chrisr is offline
Old 08-31-2009, 09:08 PM
  #59
DirkaDirka
DirkaDirka's Avatar
Oh man you ok after the fall off the bus too??
Old 08-31-2009, 09:11 PM
  #60
chrisr
Actually I didn't fall off, they ran over me and drug me for several miles before stopping to let the old guys go to the bathroom. ops: :lol:
chrisr is offline
