Beware of Novaking35 (Mike Lay)
#22
JOURNEYMAN
here is my add as copied of racing junk last year
HERE IS THE ADD AS POSTED JAN/FEB
ORIGINAL TEXT EDITS ARE NOT PERMITTED
93 red chevy short wide pickup with a 468 BBC 289 casting 4 bolt block 13.5.1 alcohol anderle injected birdcatcher hat.The motor has PORTED 781 iron heads with 194 spring good to 750 lift with 2.25 valves roller rockers with a 722 ultrdyne solid roller cam with vertical bar bullets lifters with pete jackson gear drive.Headers are big tube with evac system with 3in exhaust to turn outs.msd 6al and dizzy .Trans is th 400 with manual valve body fowared [pattern 4800 stall both are rebuilt last year by boggs .It has 6 pt roll bar matching bucket seats.The rearend is a ladder bar 12 bolt with 456 gears.Ive got a 3in cowl hood that is black that goes with it endrle 80a belt drive ....the pills in the nozzles are .38 and i think the return pill was a .48 cash or trade has title WILL TRADE FOR VERY NICE TRANS AM OR Z28
WHAT WAS NOT IN IT ?????????????????????
IF THIS IS THE TRUCK WHAT WAS NOT IN THERE ?????? IF THIS IS THE TRUCK AT ALL ?????? WTF
#24
First off it says 4 bolt main and is 2 bolt 289 casting. told me it had JE pistons in it and are trw, suppose to be eagle crank & rods and are gm i beam rods and cast crank. Pick up the truck in March and went all the way to him. Went to freshen motor up and what a suprise! Make sure it is what you say. That is why i am bitching, you lied , because you didn't know at all what you had!!!!!!!!
#28
I was going to freshen motor up, is how I found this. You can say what you want, but you said Je pistons & eagle crank rods. I just want people to know that you lied. So I will be finished now but you can finally STFU you crook!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
#29
JOURNEYMAN
BULL SHIT CRY ME A FUCKIN RIVER
NEVER SAID IT HAD EAGLE OR GE ANYTHING
ID BUT MONEY U DONT EVEN HAVE THE TRUCK OR MADE 1 SINGLE PASS
I BET U TOLD THE NEXT GUY IT HASD ALL THAT SHIT IN IT AND HE TORE IT DOWN GO FUCK YOUR SELF U LIL FUCKIN WEASLE
