Tubes or no Tubes !!!
Old 11-25-2010, 05:22 AM
  #21
TheRabbit
TheRabbit's Avatar
Originally Posted by spib
I mounted some quick time pros on my wifes 67 this last yr, 4,000lbs or more
a guy told me to use this on both sides of rim lip right before mounting,
http://www.jamestowndistributors.com...ct.do?pid=9400
no tubes no leaks
I have tubes on my blazer
wont run them again
I use to run tubes a few years ago. I had one tube that had been in a tire so long it bonded to the tire. It was a pain in the azz to cut it all out. Still never got it all out and I'm sure the tire was out of balance , but that's not a problem for my tires. I do use a little black silicone around the bead to keep from leaking, but it's a pain to clean the bead when you put another tire on.
If it's a rim problem I've also had to use a little green slime. Wipe it all over the rim don't pour it in through the valve stem it takes way to much to do it that way.
TheRabbit is offline
