radial tires vs bias ply on my trailer
Old 05-25-2012, 06:05 AM
TheYellaBrick
TheYellaBrick's Avatar
NAA, Ken ! You're LEARNIN' !
TheYellaBrick is offline
Old 06-01-2012, 10:18 AM
bixblk
bixblk's Avatar
Default update.... you folks will be proud of me
wanted to update you folks I did get my 4 tires for my trailer.I got E load radials. not mounted yet but should be fine. Here is the good part I got the 4 tires on monday 5/30/12 and I took them to my buddies shop to get mount them but he very busy so I left them. In the meantime on tuesday my daugter called the following day Tuesday 5/31/12 to tell me that 8 tires were delivered to the house and they are sitting in front of the garage.So I asked her to tell me the size and manu.I was excepting tires and rims for the 94 buick but I already got the trailer tires. Well guess what another set of trailer tires . So I called the vendor and they said no you only got 4 tires and charged for 4 tires. well I insisted, and had to talk to three different people to explain that I got an extra set of tires and did not want them and that I did not get charged for them ?????
I think I did my part, I think they are sending a RMA to get them back,
WOW ???????
bixblk is offline
Old 06-01-2012, 10:27 AM
Harbone
Moderator
Harbone's Avatar
at least you are honest, most people would have just kept them...
Chris
Harbone is offline
Old 06-01-2012, 02:08 PM
bixblk
bixblk's Avatar
Default update
UPS came and got the tires today ...oh well
bixblk is offline
Old 06-02-2012, 03:52 AM
outlaw256
well thanks DD,but im not learnin, i knew that along time ago, its just true im a cheap bastar-.i dont drive it or ridin it or on it so i aint spendin alot of money on tires. besides in my case i dont go very far anymore anyway.but if i had a distancde to go id make sure i had regular trailer tires on it.
outlaw256 is offline
Old 06-30-2012, 12:24 PM
Trulyvintage
Default Are tires ST rated ?
Are your tires ST rated ?
Note that the speed limit is 65 m.p.h.
That means you should limit your speed to 65 m.p.h. or less
while towing - going faster will cause heat build up and lead to
tire breakdown from the inside out.
Make sure you have a spare in good condition that is a radial.
Jim
Trulyvintage is offline
Old 07-01-2012, 11:14 AM
bixblk
bixblk's Avatar
Default spare
Thanks,
I have a spare that is brand new, non radial.
I hope that will work for short trips to the track ?
bixblk is offline
Old 07-04-2012, 12:01 PM
  #18
Trulyvintage
Default Re: spare
Originally Posted by bixblk
Thanks,
Any spare is better than none, just don't keep it on too long.
Radial & bias tires don't mix
Jim
