Anyone heared of a 288 cid chevy (destroked 350)
A very good friend of mine use to run the 288 cube engine's back in the 70's he was index racing and it was weight per cubic inch .
He ran it in a Vega i will see if i can find some of the pic's and info on his engine he passed away last year . racing was all he lived for .
Year: 1972 / 1973 / 1975 (the last year of pushrod engines)
Mechanic: Smokey Yunick
Engine: SBC 3.875 bore x 2.2 stroke
Induction: Twin Turbo
HP: 1,000 at 6,800RPM - 1,300 at 9,600 RPM
Quote from Smokey: "more mid range torque than I care to talk about"
Correct me if im wrong but I beleive that was a grumpy jenkins combo that required main bearing spacers. I still have a set of spacers new in the box for a 400 chevy block when putting a 327 crankshaft in it!
400 Main = 2.650 dia
Large Journal - 2.465 dia
Small Journal = 2.300 dia
Rods:
400 and large = 2.100 dia
small = 2.000 dia
(And the newer aftermarket Honda 1.888)
Cool, you are correct on your parts application to put a 262/267/302/305/307/327/350 large journal crank into a 400.
Good info Zip i'll keep that in mind! I originaly had them for a combo we were trying to build if my memory serves me correct i thought we were using a oldsmobile rod with a short skirt piston. wound up scrapin the build when we closed our shop up.
