got the vega runnin....
Old 08-15-2011, 04:35 PM
bbchevy
Default >?
GREAT!!!
Later G 8)
bbchevy is offline
Old 08-16-2011, 11:25 AM
melson3086
JOURNEYMAN
What size jets is in the new carb
melson3086 is offline
Old 08-16-2011, 03:28 PM
mwbrasher
JUNIOR BUILDER
hey pat.... give me a call... 80... 84... mark 8) 8) 8)
mwbrasher is offline
Old 08-23-2011, 11:15 PM
contagious
Default motor
The 50 cc pumps may hurt the 60'.Thats a lot of fuel to burn with starting line rpm.?Just enough not to stumble is all you want for the best 60'.
contagious is offline
Old 09-10-2011, 06:34 PM
mwbrasher
JUNIOR BUILDER
well went to the trac.... bad day... first run went 1.6 ... better 60 ft...found that the carb linkage moved... crap.....next run.. better 1.59... alt quit working... next run .... i thought it was running great... sounded like i had the thing realey wound up... not.... 5500 rpm"s.... found that the old school way of listen till it sounds "right ... then shift"... not..... motor needs to be at 7000 to run right.... soooooo.. bought a new "elect tach with shift lite!!!!!!!..... back to the drawing board.... will try again soon....... thanks for being understanding... with us older guys!!!.. thanks caveman :? :? :?
Old 09-23-2011, 02:41 PM
mwbrasher
JUNIOR BUILDER
well ... we are going to the nastalga drags here in tulsa on sat the 24 ... with any luck we should be ready... will report after we run.... hope for 10:99 or beter.... any sugestions?????? thanks in advance... caveman :? :x :x :x
Old 09-23-2011, 06:07 PM
TheYellaBrick
TheYellaBrick's Avatar
Suggestion; Peddle reeeeeeeely reeeeeely FAST !!
OH ! And have a TON of FUN !
TheYellaBrick is offline
Old 09-25-2011, 08:18 AM
  #18
mwbrasher
JUNIOR BUILDER
well..... not so good.... seems the more i work on it the slower it goes... had timing set at 38... ran a 159 60 ft... thought it was to ... went far adv... went to 34... 178 60 ft.... set timing again to 36... went 178 60ft ...AND slowed down to a 11:90 at 113.45..... i am realley getting confused....i think i'm going to have it dyno'd... cars runs great...no stumble ... no flat spots... seems to run good through the lights.... no mph or et for what i've spent.... any sugestions are highley apperciated.... thanks...caveman... :? :? :? :?
Old 09-25-2011, 07:47 PM
  #19
You can run 40 to 42 degrees with that small of an engine, i've run as high as 44 degrees with a 358" with tunnel ram and 660 ctr squirter carbs. in a 3,000 lb 66 Nova, it ran high 1.40's and 10.70's.
Old 09-25-2011, 08:35 PM
  #20
mwbrasher
JUNIOR BUILDER
thanks zip.... i was going to run it at 40 ... but wasn't sure if you could "getaway" with it that high... i adjusted the timing by "ear" where it seemed to like it ... 46degrees ... i thought o hell no..... but you may be rite... it likes the timing.... thanks for the suggestion..... caveman 8) 8) 8)
