need help with front coil springs
I have done it all different ways. I've used all thread,I've tied the car down and used a floor jack,and I've used a Spring compressor..but by far the best way is this.
Originally Posted by Tod74
Look in the yellow pages for a spring place.There is a place in Indy that sells springs and For around $20 they will compress a pair of springs for you and band them together.You just instal everything then reach in with some cutters and cut the band.
Originally Posted by DrivingMissDD
ESPECIALLY for this particular job, I would NEVER use a cheap Chinese junk tool. :shock: :shock: :shock: :shock: Good way to loose your head !!
Load it on a car trailer and tie it down to so you can use a floor jack under the 'A'arm to compress it.
Everything has something to do with some or part of it from over seas anymore.
Everything has something to do with some or part of it from over seas anymore.I'm talking about the quality of the parts that critical tools are made of. One little single weak link in the multiple parts that make up a spring compressor and that spring explodes. Looking back on all the times and methods I've used to compress automotive coil springs, it's a wonder I've still retained my OWN head ! :shock: :shock:
ops:
ops:
