Got to love the idiots of this world
Old 09-17-2009, 03:47 PM
newjack42
JUNIOR BUILDER
wow never heard of that one before :shock: thanks for the idea DD
newjack42 is offline
Old 09-18-2009, 03:23 AM
CamBirdRacing
Dang DD, you beat me to it.
If you have a pipe plug that won't come out, take your torch and heat up the center of the plug, let cool and it will come right out. don't heat up around it, just the plug.
CamBirdRacing is offline
Old 09-18-2009, 09:56 AM
TheRabbit
TheRabbit's Avatar
Originally Posted by DrivingMissDD
Heat the stud up with an oxy/accet torch to a glowing red, then touch a candle to it. The wax will wick into the threads. Let it cool completely to the touch and then twist it out. Magic.....
Never heard that before. Hope I don't need it anytime soon, but want forget it!
TheRabbit is offline
Old 09-18-2009, 12:13 PM
Scooterz
Double/D,
That's really cool. I did not know that....
Scooterz is offline
Old 09-21-2009, 07:41 AM
oldandtired
oldandtired's Avatar
Great ideas all around. The main thing is patience.
Dave
oldandtired is offline
Old 09-21-2009, 08:57 AM
signsbyesa
dd's way works great and i have used another way and it may
sound dumb but it works great only if there is room on the stud,
put a nut down then a washer and then tighten with another nut
and work the first one off and it will titghten on the washer and
work off, also spray with wd40 and if you have a can of butane
spray it for a while to get it frozen and then work the nut against
the washer/nut and it worked for me, only if there is room,
good luck :wink:
signsbyesa is offline
