compression
Old 04-08-2009, 07:38 PM
bbchevy
Default HP
$400 HP NOT CLOSE.
Try 260 to 270HP Stock.Thats aLL...........
Later
G 8)
bbchevy is offline
Old 04-09-2009, 03:10 AM
CamBirdRacing
Maybe 400 lbs of torque, but not HP.
CamBirdRacing is offline
Old 04-09-2009, 02:01 PM
Scooterz
Yep about 250-260 sounds about right. A 1992 350 truck (C/K 1500) application w/ TBI all stock was only about 155/hp!! You would be surprised how little HP they had.
Scooterz is offline
Old 04-09-2009, 03:55 PM
killapits26
APPRENTICE
i knew it didn't feel like it had alot, so i got to do something about that trying to make a nice show truck with a little pep
killapits26 is offline
Old 04-09-2009, 04:05 PM
tcarda
Is your 1990 a Gen V block? If it is, I think you will have to find some heads for the Gen V block for the upper water hole alignment. I am not positive, but you will have to check it out.
tcarda is offline
Old 04-09-2009, 04:17 PM
MEMRACING62
EDELBROCK SELLS PREFORMANCE PACKAGES WITH HEADS CAM MANIFOLD ETC THAT SHOULD DO WHAT YOU ARE LOOKING FOR. WITH TBI & EMISSIONS YOU ARE KINDA LIMITED. CHECK THEM OUT. MIKE
MEMRACING62 is offline
Old 04-09-2009, 06:59 PM
Tod74
PISTONS ARE WAY CHEAPER THAN HEADS.
Tod74 is offline
Old 04-09-2009, 08:00 PM
  #18
killapits26
APPRENTICE
i was wanting to switch from the 2 barrel tbi over to the efi from edelbrock or just convert to carb
Old 04-09-2009, 08:56 PM
  #19
Is this a duelly truck by chance :?: I wouldn't touch it if it is, i can guarentee you that the Edelbrock EFI, will not be worth the $2,000.00 over the throttle body. If it's conventual truck, not a duelly, you'd be better off to change the heads, and up the cam a little and stay with the throttle body. I've got a 1993 duelly with 189,000 miles on it and it pulls a 28 ft Haulmark with an over 3,000 lb car all day as fast as the speed limit allows, and will still spin the tires with no load on it, i wouldn't touch it for nothing. It's never had any engine work done too it, but i'm a little surprised that the plastic timing gear hasn't gone out yet.
Old 04-10-2009, 02:10 AM
  #20
killapits26
APPRENTICE
its a standard truck 1990 chevy ss just want to get more out of it
