Milky oil and alcohol
Old 06-02-2011, 03:24 PM
  #41
kod99
Default Re: Parts
Originally Posted by bbchevy
Originally Posted by kod99
Hot leakdown test was even worse. Pulled engine and sent it the engine builder to be checked out.
Smart move, before you ran it again.
I do learn....it just takes me a while.
I'm gonna put on a 0 1/2 pump, 80 pill and 39 nozzles and tune from there.
I Can HOOK you up with ALL of those PARTS,INCLUDING a Nice T-2 Terminator and a Primer +.Just Posted the Whole System,in the Classifieds.
Hope things are NOT to bad,and maybe a Finish Hone and a set of Rings.....?
Later
G
Thanks bbchevy. I have everything I need, I just need to start with the correct settings.
kod99 is offline
Old 06-05-2011, 04:21 PM
  #42
fast75vega
i was told of a good way to stop milky oil and help get temp up :wink:
an old timer told use to run a vac vent line from the manifold in side the car with a valve on it .... this way when you open it.... it sucks air to lean it out and will get the temp up as well. he also said to get the temp up to 200 deg. before shutting the car down
fast75vega is offline
Old 06-09-2011, 04:40 AM
  #43
kod99
The engine is apart.
Thankfully, no big damage. The ring gap was a bit big on some cylinders. Gonna replace the bearings, because they were a little washed from the excess alcohol, and install some gapless rings.
kod99 is offline
Old 06-09-2011, 04:43 AM
  #44
kod99
Thanks for the info fast.
I have a lean out valve on the car and I used it when the engine had a carb on it. With the injection, I just pull out the fuel shut of until the engine is lean.
kod99 is offline
Old 06-10-2011, 08:27 AM
  #45
hammertime
Look into rings from Wiseco or JE, low tension, there is hp in that area.
Did they say what the ring gap was ?
hammertime is offline
Old 06-24-2011, 01:03 PM
  #46
kod99
The end gap was 28 top ring and 26 second ring.
I'm gonna go to gapless top rings. Changing to a Sniper manifold at the same time. It will be a couple of weeks yet.
kod99 is offline
Old 06-24-2011, 08:33 PM
  #47
hammertime
with injection the intake is a waste but if you every do a carb again there is a gain there.
Old 06-25-2011, 06:26 AM
  #48
kod99
David,
Which intake manifold are you running with your injection system?
kod99 is offline
Old 06-25-2011, 11:05 AM
  #49
hammertime
David,
I have the Sniper on it for carb purposes and a 454R sitting here for it also.
Old 06-26-2011, 06:00 AM
  #50
kod99
David,
I saw some impressive claims of HP gains with the Sniper and assumed they were using a carb for the testing. I wondered if it did the same with injection. Now I know. Thanks, David.
kod99 is offline
