Factory 4bolt main 350SBC block Peak Horsepower
Old 11-29-2009, 02:55 PM
Tod74
the four bolt main caps alone make 75-100 hp
Tod74 is offline
Old 11-29-2009, 05:32 PM
russ67chevelle
dont forget to squeeze an extra 30 ponies with those crome valve covers!!!
russ67chevelle is offline
Old 11-29-2009, 07:17 PM
sds10racer
don't forget about those legendary pink rods
sds10racer is offline
Old 11-29-2009, 08:57 PM
DRTRCR22
And those 2.08 / 1.60 Camel Hump heads...
DRTRCR22 is offline
Old 11-29-2009, 09:09 PM
kwkracing
OOoh, i know the secret!!! They where rusty seasoned blocks!!! If you through your dart block outside during winter it should be good for another 150 hp when you machine it!
kwkracing is offline
Old 11-30-2009, 05:20 AM
cepx111
Originally Posted by hink
Its amazing Dart rates their SHP block at 600 horse the the GM blocks with stock caps are better then a Dart
Nobody ever said that GM was better than DART you did, Mr DART sellsman.
Why not just go ahead and quote the man? Instead you just read what you wanna read and then twist the words around.
I believe it was said that 600hp would be pushing the envelope, not a reccomendation, dip $hit.
Cudos on fessing up to being a smarta$$ ~> we never knew.
JMO>Cp
cepx111 is offline
Old 11-30-2009, 12:09 PM
hink
JMO>Cp
Well it seems someone here was smart an ordered an SHP block for their build and one pending after the begining of the year HMMMMMMMMMMMM
By the way we are on the deep deal on the GM Bowtie blocks as well.
Let me know what your address is and I will send you a crying towel may two of them as sounds like you them
Your Dart and Bowtie salesman
hink is offline
Old 11-30-2009, 12:22 PM
  #18
kwkracing
cant we all just get along for once?
Old 11-30-2009, 03:42 PM
  #19
Default GM bowtie
Hey Carl,
How does the Bowtie compare to the SHP block, money wise and reliability? I know that NASCAR uses them and are making over 800 HP with them.
Just curious,
Old 11-30-2009, 04:55 PM
  #20
hink
Default Re: GM bowtie
Originally Posted by zipper06
Hey Carl,
Just curious,
The Bowtie with billet caps is probably a better peice then the SHP and the GM Bowtie block has more nickel.
NASCAR has not used the Bowtie blocks for years as the are using the newer R07 blocks with the dist. in the front of the engine now.
The Bowtie blocks are a lot of money over the SHP blocks and GM is doing away with a lot block P/N in the near future.
hink is offline
