Howard's Cams
Howards Cams
Howards has been around since the 60's and possibly the 50's. They are more well known for their aluminum rods. A friend of mine ran them in his SBC in the 60's, he was very satisfied with them. Don't know anything about their cams. They probably have a website out there somewhere. You could try searching on dogpile.com
Yeah I have been to their website. Their cams are quite a bit cheaper in price than others that's why I asked if they were any good. I didn't look at them for the cost I just saw a cam they had that I liked and didn't want to buy a turd.
Howard's Cams
I have one running in a SBC, 350 .060 flat top, Its a solid lifter cam. The cam works great and sounds mean. You can hear the car/engine coming and going for a quarter mile in either direction. The car has run 12:00's at 110 m.p.h. I would not hesitate to use another grind from them. The Howard's lower priced cams are not ground by them, they are re boxed. They will do a custom grind for you, but their again I do not think they actually grind them.
92Camaro
92Camaro
HOWARDS
HOWARDS IS LOCATED IN THE SAME BUILDING WITH COMPETITION PRODUCTS , IN OSHCOSH WISCONSIN. THE SAME DOOR!!!
WE HAVE USED BOTH THEIR SOLID CAMS AND THEIR MECHANICAL ROLLERS. NEVER HAD BAD LUCK WITH THEM.
WE ALSO HAVE ONE OF HOWARDS PRO CRANKS IN OUR 430 SBC,
800 HP , GREAT CRANKSHAFT !!!!!!!!
OUR MOTOR BUILDER IS 20 MILES FROM THEM IN APPLETON WI.
I WONDER IF HE USES THEIR SPECIAL GRINDS!?!?!
WE HAVE STOPPED BY AND PURCHASED PARTS , WALKINS ARE WELCOMED, VERY FRIENDLY AND KNOWLEDGABLE STAFF!!!!!!!!
