oil brand
Old 03-13-2013, 07:54 PM
markdunlap
Default oil brand
I use and recommend BRAD PENN racing oil.
It's got enough ZDDP to suit me.
20-50 for drag racing.
Nitro 70 for blown alcohol pulling trucks.
This stuff is also so "clingy" its tough to clean off engine parts.
markdunlap is offline
Old 03-14-2013, 06:42 PM
wazup
Hell put some oil in her and let it ripp :lol:
I use vr1 20/50 with dry sump.... 35psi idle and around 75psi thru the traps
wazup is offline
Old 03-18-2013, 03:40 PM
ddf419
Going with the Schaeffers oil 20/50 no blend.
ddf419 is offline
Old 03-18-2013, 05:04 PM
hammertime
good choice, very high zinc oil
hammertime is offline
Old 03-27-2013, 10:51 AM
Scooterz
Default Re: oil brand
When do you use a straight weight oil such as 50 or 60? I don't understand what the diff is from a 50wt -VS- a 20/50 for example. I see you use it in the alcohol motor...
Scooterz is offline
Old 03-27-2013, 12:24 PM
hammertime
Here is a good read for ya to explain it at bit, most people have no clue what W even stands for.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Old 04-05-2013, 10:10 AM
Scooterz
Hey David,
I finally took the time to read the article w/o being interrupted. I understand now. I like the viscosity of a straight weight oil such as 50 or 60; but with a really good additive for cold starts. On an older engine, it seems like a good comprise in Spring/Summer in my CJ7 w/ Mopar 360 (mildly built). I see good OP @ OT & idle, but I also have a little security in those oils when the temp is quickly fluctuating like Jeeps can do. The motor is broke in well & probably has pretty big bearing tolerances- oil pressure w/ 10/40 @ idle bugs me too much when I look at the gauge & see 8lbs... I guess it is part mental too.
Scooterz is offline
Old 04-05-2013, 07:03 PM
  #18
roadkill2
Ain't it fun to learn sh*t?
Love this forum . .
roadkill2 is offline
Old 04-08-2013, 04:09 PM
  #19
Scooterz
RK: INDEED!! I have learned so much from these dudes.... I got all my carb knowledge here... sometimes at 1AM in the morning. Other times, RJ saved me much pain in the wisdom gained.
Scooterz is offline
Old 04-08-2013, 06:29 PM
  #20
wazup
I know what the W means im a winner :lol:
wazup is offline
