fuel pressure and filter
Old 12-28-2012, 04:27 PM
hammertime
Originally Posted by TheRabbit
Try running one with the filter and then take the element out, you may be shocked.
I never run one after the pump, to much restriction.
That's actually backward. Pump is gravity fed with pressure on the out side.
I don't run one before the pump. :wink:
A/B test one with the filter before and after the pump, report back with the egt and o2 readings I've seen it first hand (atleast with a 8an earls in line filters after pump) they can cause a bit of restriction.
I quit running filters and use a outterwears filter when pumping fuel now.
hammertime is offline
Old 12-28-2012, 04:41 PM
TheRabbit
TheRabbit's Avatar
NO WAY I'm running a 8an filter.
The BG filter is screwed directly into the Areomotive pump on mine.
Feeding this with an 8 aint' gonna happen. lol
36N
32N
28N
TheRabbit is offline
Old 12-29-2012, 05:15 AM
hammertime
8 an from the pump is common on just about any fuel log application.
ps ... that looks cool as hell !!
Old 12-29-2012, 08:13 AM
wazup
Dam Rabbit i think you need a 20an to feed all that lol. Thats a bad a$$ looking setup you got. Love it.
wazup is offline
Old 05-03-2013, 10:44 PM
reno2486
u see Aeromotive, they suggest associate degree alcohol one hundred fifty steel mesh filter before the pump and a paper forty mesh filter before the carb. i assume everybody did not move to an equivalent filter faculty in school.
I simply use the one hundred fifty mesh before the pump. Not an excessive amount of restriction, nonetheless keeps out any larger debri from reaching to the needle and seat on a carb.
2013 MERCEDES BENZ SL-CLASS
reno2486 is offline
