Launch Tuning
Old 07-12-2012, 03:48 AM
wmeabates
Zip,it sounds like the car is going left when the track is good,by limiting or slowing the travel of the left front it will let the right front load the left better.Once the wheels are up that part is over.Still might be in the tires though.Bill.
wmeabates is offline
Old 07-12-2012, 05:26 AM
dirt91
right about the age of the slicks but they were stored properly and have very few runs on them but it still could be. The problem is not carrying the LF the real issue is that on a clean hot slick track it goes straight.... later on when the track cools off and rubbers up it pulls hard to the left, too much to make it consistent. I have to steer it hard and lose about .08 to hold it off of the center line or wall. it seems to yank left and right up about equal amounts, except the better the track gets it jumps to left on launch.
Thanks for all the input!
dirt91 is offline
Old 07-12-2012, 06:13 AM
TheYellaBrick
TheYellaBrick's Avatar
Are all of your rear suspension pivot points solid with zero play ? A slick track gives you more wheel spin so any looseness wouldn't be as prominent as a hooked up launch.
TheYellaBrick is offline
Old 07-12-2012, 07:58 AM
itsabird
Do you have adjustible springs in the rear, if so check right rear spring height, you may need to load the left rear spring a little more.
itsabird is offline
Old 07-12-2012, 11:19 AM
dirt91
all suspension points seem tight, I have found that I had about 5/8 more travel in the LF before it comes off the ground than the RF ( I have evened that out with a travel adjuster). I will either have to shim or spring rubber the LR spring, they are stock type coils.
dirt91 is offline
Old 07-12-2012, 12:45 PM
itsabird
You might think about a set of air bags, they may help.
itsabird is offline
Old 07-12-2012, 03:18 PM
wmeabates
Do you think you might have put a little more preload in the r/r than you needed?Maybe you can take some of it out and still ok early in the day. Bill.
Old 07-12-2012, 05:21 PM
  #18
mopar1968
mopar1968's Avatar
According to Jegs the smallest set of hoosiers-Do5 is 30x9x15, So i agree better check your slicks :!: :!:
Mark
mopar1968 is offline
Old 07-12-2012, 05:23 PM
  #19
dirt91
Bill, that is exactly what i'm thinking lol, but to change it will require cutting and re welding the frame mount bracket.... which I already have made the replacement pieces to do that but since it worked so good early I was hoping to tune around it. Mark, I'm in on new slicks. These just work really well early so I'm trying to get as much out of them as I can since they are like new.
dirt91 is offline
Old 07-13-2012, 04:45 AM
  #20
wmeabates
Ok Dirt now I got you.When you said non adj.I thought you just did not have the link to adj.them on the car without disconecting them.I had a ladder bar car with stock coils&shocks that worked good with 1/2 inch right side preload,it that tells you anything.Bill.
