Will this engine be worth it?
Old 06-05-2012, 07:27 AM
spib
I ran a best of 12.38 with a 9to1 355 with 470 lift cam a $1800 long block, but thats with a 4500 vert and 4.86 gears, right at 3200lbs
spib is offline
Old 06-05-2012, 03:42 PM
bluedawg357
CRAFTSMAN
If your planning a small block build and planning to go with a forged crank, it really doesn't cost that much more to stroke it out to a 3.75'' stroke and end up with a 383. In my opinion well worth the extra money and labor.
bluedawg357 is offline
Old 06-05-2012, 05:30 PM
laxking012
JUNIOR BUILDER
I've actually have considered a 383, but don't really know much about that kind of build.
laxking012 is offline
Old 06-06-2012, 04:19 AM
outlaw256
the machine shop will take care of the bottom end for ya.well the maching anyway. the rest is the same as anyother build.ive got a 383 in my 53 ranchwagon, and it is FAST.ive shut down a few on the street with this heavy car. suprise, suprise, suprise.!!! i love it. if you arent sure on how to build one just get ya a book read a little and spend alot! lol
outlaw256 is offline
Old 06-06-2012, 05:50 PM
hotrod1994
383 is a 350 bored 30 over with a 3.75 stroke yeah just tell the shop u want it machine to be made into a 383 and they will get ya going its the same as building any other engine just different parts and go with a 6.0 rod it reduces outward pressure on the cylinder wall making it more efficient
-logan
hotrod1994 is offline
Old 06-06-2012, 06:24 PM
csx8506
SENIOR BUILDER
Default s10
Laxking,
You can run 12.25's with a 350 at .060 over, stock stroke in a 3000# S10, powerglide, 4.56 rears, that's what mine runs in cool weather. Most of the time I run 1/8mile at 7.75's at 88-90mph. And it has the stock s10 rear end with traction bars. I race at 350' above sea level, that helps a lot. It wouldn't surprise me if my rear end fell out on the next run, but I've been running this same combo for about 4 years with no problem. It also has mid 70's smog motor heads, but it has a good cam, intake, and all the other parts. I went with smog motor heads because they are cheap, and I had them, and comp ratio worked out to be 10-1 so I could use pump gas 93 octane. Hope this helps you some. dgh
csx8506 is offline
Old 06-07-2012, 04:35 AM
laxking012
JUNIOR BUILDER
Thanks everyone for the replies, giving me a few things to think about doing. As far as going 383, I've seen Summit has bottem end packages from Scat and Eagle, are these a good way to go, or what should I be looking for as for parts to build the 383?
Old 06-07-2012, 10:14 AM
  #18
hotrod1994
the rotating assembly are a good start or you can do it like this
FORGED 3.750 stroke crank for a 350 a good block bored .30 over and notched for clearance, forged 6.0 rod, some high dome pistons, aluminum heads (everyone i talk to THAT RUNS PROCOMP says procopm is good for the money) and a good cam to fit the build. thats how i would do it
JMO id go with forged crank and rods if you can afford them just for extra insurance but the scat 9000 crank is a good cast crank from what i hear
-logan
Old 06-08-2012, 02:18 AM
  #19
outlaw256
watch what company crank you buy very close. scat is a import blank crank.meaning they import the blanks and turn them. meaning softer steel or iron.
Old 06-08-2012, 09:45 AM
  #20
hotrod1994
ive herd the scat 9000 cranks run at 7000 rpms and take 550 hp without a problem
J.M.O
-logan
