A-ARM 2x3TUBECHASSIS HELP
Old 02-11-2012, 02:53 AM
  #21
injectedrat68
APPRENTICE
Default post subject
Thanks zip.
injectedrat68 is offline
Old 02-11-2012, 09:53 PM
  #22
olds48
Just my two cents-ignore if need be-but definitely get a grain of salt ready. I picked up a fox body tubular k-member with everything on it.Adjustable struts,nice brakes...the whole nine yards.CHEAP-thanks to Gimmethakick.Anyways,when i went to attach to the front of my car all i did was pop the springs off the struts-level the lower control arm to the ground and adjusted the height of the spindle according to the size tire I had on the front. Whatever the center line of the tire was ( i dont remember) I sat the center of the spindle at that height. I pushed the axle center line forward cuz i never thought the front sat where they where they looked good-then just burned it all in. But cant you do the same here? Just put the spindle as far forward as you want it and then measure off the floor according to tire height? Like I said,just my two cents. Probably not worth that much,really. Just a thought. Good luck with your project!
BTW: Anyone even remotely close to the Roanoke VA area should contact Gimmethakick if they need any parts. Ya'll may already know,but he runs a speed shop in that town and would really appreciate the business.Of course he can ship as well.SUPPORT ONE OF OUR OWN!
olds48 is offline
Old 02-12-2012, 04:20 PM
  #23
coolracing
Default Re: post subject
Originally Posted by zipper06
Originally Posted by injectedrat68
Whats the rule on 2x3 when you add on. You have to plate it and over lap by how much i would think on all 4 sides. Any special way i should notch the 2x3 to butt togeather, or just butt them togeather flush. That doesnt look right by putting togeather flush.
I have butt welded 2X3 frame rails but i welded a 2"X4"X1/4" tk plate on each side of the butt welded section.
Exactly what zip said! That method has been used since the old gasser days!
coolracing is offline
Old 02-13-2012, 02:30 AM
  #24
injectedrat68
APPRENTICE
Thanks, ill let yas know how the project is going between some of my other jobs. I dont think i can get to the camaro for about a week. Thanks Paul
