Gutted the interior
Old 01-06-2012, 06:49 PM
TheYellaBrick
TheYellaBrick's Avatar
GORGEOUS !!
Ever used Lizard Skin sound and heat insulater ? I've coated top and bottom of the floorboards in both my race cars and it 'REALLY WORKS' !
I brushed mine on, or you can use an undercoating gun.
Eastwood;
http://search.eastwood.com/search?w=...&p=Q&ts=custom
Speedway Mtrs;
http://www.speedwaymotors.com/search-Lizard-Skin.html
TheYellaBrick is offline
Old 01-07-2012, 05:06 PM
Harbone
Moderator
Harbone's Avatar
Actually DD I used a product called Peel & Seal from Lowes, its identical to Fatmat and about half the price.
The stuff works great, use a wallpaper roller in the tight spots and it cuts easy with just a razor.
3 rolls knocked out the floorboards, gonna have to go buy 1 more tomorrow to do the doors and behind the back seat.
So then I tore into the cluster, got a good deal on a housing with solid tabs and a nice lens. The temp, amp and fuel gauges are in surprisingly good shape. I will be ordering the oil psi gauge from Gaugemarks here shortly. The circuit board has some minumal delamination but everything still works so a good cleaning, some new screws and polish up the old screws and it looks pretty good!
Hope to get the door panels off tomorrow and insulate them. Need to start on the dash warp too hopefully Sunday
Chris
Harbone is offline
Old 01-07-2012, 05:13 PM
TheYellaBrick
How thick is that Peel n Seal ?
Is it made to insulate(temperature) or deaden(noise)?
Am really enjoying the 'in progress' shots ! :
D
Old 01-07-2012, 05:25 PM
TheYellaBrick
I just did some research on the Peel n Seal on the manufacturers website.
It doesn't appear to be a real affective insulator in it's mass, but reflects heat by it's lighter color and texture on the outside. I'm for sure going to get some to redo the roof on the 'Gearhead Motel' though ! Thanks for turning us on to it, 'Bone!
Old 01-07-2012, 06:00 PM
Harbone
Moderator
Harbone's Avatar
The stuff works excellent, some guys on the NastyZ forum turned me onto it. Some people say they use a blow dryer or heat gun to make it more flexible but I never needed to use either, just some pressure and smart cuts. Heres a pic of the product Fatmat compared to Peel & Seal and they are identical.
Chris
Harbone is offline
Old 01-10-2012, 04:41 PM
qtrmile2
Looks awesome. Alot of work to be done but it looks great. Nice job.
I know what your going thru it's definately alot of work but it's worth it when done.
qtrmile2 is offline
Old 01-11-2012, 11:06 AM
Harbone
Moderator
Harbone's Avatar
I like this kind of work though, hate body work, prep and paint. The car has great paint and the engine compartment is just a knock out. That makes me want to be as detailed as possible on the interior so it can match up the rest of the car!
Chris
Harbone is offline
Old 01-14-2012, 05:46 PM
  #18
Harbone
Moderator
Harbone's Avatar
Worked on the dash curl about 2 hours this morning. Burnt the heck out of thumbs and forefingers even with gloves on. What a PITA, I got the big curve out of it and the vinyl glued back down on the fiberglass frame. Might heat it up one more time and try to get it don just a little more. Heres the before pics.
Here is what it looks like now.
Chris
Harbone is offline
Old 01-14-2012, 06:47 PM
  #19
lively
lively's Avatar
BIG DIFFERENCE 8) 8)
HEAT PROBABLY RUINED THAT MANICURE--I JUST HATE THAT :cry: :cry:
lively is offline
Old 01-14-2012, 07:06 PM
  #20
coolracing
So how did that POR come of ur skin when you got it on ya! :lol:
coolracing is offline
