ALCOHOL
Old 07-22-2010, 09:20 AM
curtisreed
curtisreed's Avatar
Default Re: Carbs?
only down side is it uses more fuel each pass but cost='s out anyways.
I been running alky for years, injection, several different carbs.
Anyone that does anything extra vs gas is doing it for nothing. I make a lot of passes a year, dont drain the fuel dont run upper lube (wait till you get some bad stuff that gums up a carb once you'll love it to) I change the oil the same as I did with gas (50-55) passes. Rebuild my engines the same. There is to many people who make it harder then it should be
Yep Dave,
Them Damn CARBS gum up ALOT!(On My John DEERE)Cause thats the ONLY Place you SHOULD Have a CARB!!!!!!!
Later
G
lol My injection got taken off last weekend and a carb put on it :shock:
but they sure do gum up if ya dont watch it, and some top lubes are horrible.
Hey David,
Why did you pull the injector off? Doing some super racing?
Curtis
curtisreed is offline
Old 07-22-2010, 10:45 AM
hammertime
Default Re: Carbs?
Yep Dave,
Later
G
Hey David,
Curtis
No no super racing for me, going in for surgery next wed and my racing is done. Not everyone understands the injection/primer. Carb you jump in and go race so anyone can drive it now.
hammertime is offline
Old 07-22-2010, 10:57 AM
curtisreed
curtisreed's Avatar
Gotcha. I hope everything goes will with the surgery.
Curtis
Old 07-22-2010, 11:23 AM
hammertime
Curtis
thanks, surgery #2 on samething first one didnt work .. got to love docs
Old 07-22-2010, 02:59 PM
Default Re: Carbs?
Yep Dave,
Later
G
Hey David,
Curtis
WHEW!!! for a moment i thought you were putting a John Deere motor in it :P
Old 07-22-2010, 03:43 PM
BEAST477
BEAST477's Avatar
Curtis
Good luck David, hope things go better this time.
BEAST477 is offline
Old 07-22-2010, 03:50 PM
hammertime
anyone like to take a guess the ET difference on a 582 between a rons terminator and a 1150 APD alky carb ??
Old 07-22-2010, 03:51 PM
  #18
hammertime
thanks Mike
Old 07-22-2010, 03:59 PM
  #19
curtisreed
curtisreed's Avatar
A loss of .232
Old 07-22-2010, 04:16 PM
  #20
shawnp
Am I allowed to guess? Want to guess what an alky carb picks up going from 114 rollout to 108? LOL
On the alky, love it. Never get the car over 180 degrees in eliminations. Have had the car double entered and triple entered putting 2 or 3 runs on the car within a 20 minute span. Fuel it and go!! On all the motors we have tore down, never have I seen any signs of alcohol causing any effect to the motor.
shawnp is offline
