VP Q16 ?
Old 05-26-2010, 04:15 PM
dino17
Default Q16 "Works"
We use it on the 598 BBC. One thing i did do was send the dominator to
Pro Systems and had it Spec'd for Q16. Car was running 7.85's in the dragster with 114. Added fresh with q16 and no timing changes. Jetted up from 98 square to 104's and clicked the car off @ 7.54 /175. If you Stay with Q, stay on the plug inspection. As per Patrick at Pro Systems Q fuel is a beast if you know what i mean. Good Luck!!!
dino17 is offline
Old 05-30-2010, 11:04 AM
flight71
JOURNEYMAN
I switched from c-16 to Q-16 while on the dyno and made 32 more HP with the Q with a 427inch small block, bumped the jetting up 4 in front and rear, and everything they say about it being corrosive and draining fuel system after every race is true, keep it in a sealed metal container as well. Stay on top of plugs, lack of dye in the fuel seems to make them a little harder to read in my opinion
flight71 is offline
