Any special tricks with edelbrock carb?????
Old 01-22-2011, 11:17 AM
lanham
I have had both the Edelbrock and Carter brand carbs in the past on a street vehicle and neither one of them ran right but i guess for a street vehicle they are okay if you already have one but definitely are not for perfomance.I switched mine out for a Holley and was a huge difference.I would never buy a new Edelbrock or Carter Carb ever again.
lanham is offline
Old 01-22-2011, 08:32 PM
fast75vega
Originally Posted by jeepfreek
Spend a couple bucks and do an O2 sensor in the exhaust with a digital gauge from either Jegs or Summit. Set the timming to best vacume at idle, this will need a good timming light with dwell. Follow what everybody else and your carb jet chart says to get a good baseline and when thats set just follow what the O2 sensor says to get best lean! I did this before taking my Jeep to the dyno shop and they spent an hour trying to get it better but ended up with my settings in the end, proof that it works I guess?
so what kind of numbers should we be looking for then on an alcohol carb and a gas carb motor :?:
fast75vega is offline
Old 03-14-2011, 12:08 PM
Leoatcobrapower
Default Re: Any special tricks with edelbrock carb?????
Originally Posted by cepx111
Originally Posted by shortysracing
Anyone know any special tricks to do with the edelbrock 750 performer carb.
They make good boat anchors.
Oh wow!
Leoatcobrapower is offline
