front runers
Old 01-29-2010, 07:14 PM
Originally Posted by Pdmracing
Originally Posted by BEAST477
I run Moroso front and MT rear. Hey Shawn I found that coating the sidewalls with dish soap using a foam brush has solved the leaking problem. So far so good anyhow.
stupid question, coat the inside of tire or out?
Thanks
Inside i have found if you put about 8 oz. of dish soap inside the rear slick if you don't run tubes, it somehow seals the leaks. I don't know about front runners, because i've never had them leak that much. But i don't run dragster front runners.
Old 01-29-2010, 07:34 PM
cepx111
Thanks
X2
My phoenix rear slicks used to leak like a sum biitch, took out valve core, poured in approx a cup of dish soap in each one & wallah, no more leaks.
Cp
cepx111 is offline
Old 01-29-2010, 08:47 PM
bjuice
Administrator
bjuice's Avatar
the soap acts as a home remedy of FIX-A-FLAT..just run tubes on rear,we have found some of the local high hp oulaw guys are having fewer tire shakes with rear tubes and they are just as quick.while the guys not running tubes claiming too much rotating weight and heat
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 01-29-2010, 09:15 PM
mopar1968
mopar1968's Avatar
Moroso on front, Hoosier on rear :!: :!:
''JUST MY TWO CENT'S WORTH''
mopar1968 is offline
Old 01-30-2010, 08:30 AM
Pdmracing
CRAFTSMAN
Thanks for the tip! :P
Pdmracing is offline
Old 01-30-2010, 11:27 AM
br1984
APPRENTICE
Default tires
thanks for the info guys i have hosiers on the rear so i bought them for the front
br1984 is offline
