ladder bar help
Old 01-09-2010, 03:34 AM
  #31
mikesramblur
JOURNEYMAN
this should give you an idea.
i couldnt get it high enough at the frame rails so move it forward enouth to take up the length of the bars. this is where it wanted to be so out comes the floor.
lots more pics here. let me know if it dont work.
http://s87.photobucket.com/albums/k144/mikesamc/
mikesramblur is offline
Old 01-09-2010, 11:27 AM
  #32
Tod74
my floor was cut as well.
Tod74 is offline
Old 01-09-2010, 05:09 PM
  #33
cam67152
x-3
cam67152 is offline
Old 01-10-2010, 06:35 PM
  #34
amcjunky
JOURNEYMAN
mikes ramblur did you have to cut up your trunk at all to get your upper shock mount to work? or any of you have to cut your trunk up?
here are some more pictures of my progress
and i am getting someone else to do all the welding everything is just tack welded into place at the moment
amcjunky is offline
Old 01-10-2010, 07:52 PM
  #35
itsabird
don't forget top bar, for upper shock mounting brackets
itsabird is offline
Old 01-11-2010, 05:43 AM
  #36
mikesramblur
JOURNEYMAN
im working on a 79 spirit. no trunk. but i did have to do some trimming near the frame to get the upper shock mount pipe in. i shoulda plated it before attaching to the frame but ....
i dont think you will have to go into the trunk.
hard to tell by the pics, did you attach your xmember at the frame? or rockers?
Old 01-11-2010, 07:08 AM
  #37
TheYellaBrick
TheYellaBrick's Avatar
2 suggestions;
- Install new brake hardline from the master cyl to the rear axle. Looks very rusty/weak and you got mighty close during the hole hogging in your rear foot well.
- Where the ladder bar mounts attach to the rear axle tubes, it needs to be ground down to bare metal on the tubes for best weld penetration. REMOVE to grind, do NOT try to edge grind the area with a grinder ! Your welder guy will NOT weld it as is if he's conscious about his weld quality.
Looks good in the placement of all parts and pieces though !
TheYellaBrick is offline
Old 01-11-2010, 02:19 PM
  #38
amcjunky
JOURNEYMAN
well everything is just kinda sitting there lol i bungee corded the ladder bars to the axel so i could move them around and to get them to stay on there. i will be redoing the brake lines to make them fit around the ladder bar.
and mike I attached the x member to my frame connectors. I had to move it up in my floor quite a bit tho but I don't think that should matter to much I hope
amcjunky is offline
Old 01-11-2010, 04:42 PM
  #39
promod45
JUNIOR BUILDER
Default another thought
another idea for you is i would put a heavy ford rear in car since you are this far so that if you ever change gears you can do it on the bench and ford gears are dime a dozen, also when you put your roll bar in make sure you put one bar on the body and one bar on the new cross member on each side of the bar this will help alot in tying it all together..
promod45 is offline
Old 01-11-2010, 07:46 PM
  #40
cam67152
I would try to tie a bar in between the rocker, subframe, and new x-member. JMO
Looks like your making some good progress :!: :!:
cam67152
cam67152 is offline
