NOS and Compression Ratio
Ash, if my failed minnow joke to oldandtired the other day, came off as accusing you of "telling fishing stories", I appologize. I was telling fishing lies to oldandtired. Once again I appologize.
Originally Posted by ashbros
with a small block i would not consider spraying less than a 150 shot.
A street motor for crusing 100-150.
A lot of guys around my area tend to run 12 to 1 compression, with race fuel. The nitrous seems to respond quite nicely.
On another note, back when my boys were 14 a6 16, I gave them a few bucks to throw a little budget motor together, It was built for the use of nitrous in mind except their budget did not allow them to use forge pistons.
Stock block 4 bolt 355 CID
Gm Steel Crank
Stock GM Rods with arp Bolt Upgrade,
Hyperutectic pistions - they were cheap....
The cam was not to big 515 lift intake and exhaust
I had a super nice set of brodix track 1 heads that had been work over by Ron's porting
Strip dominator intake
Jimmy Evans 950 Blower carb
125 Shot of Nitrous.
clevite bearings
Can't remember what rings they used.
On the nitrous this was a really strong motor, but the thing that caught my attention was the boy ran a bill up at the neighbor hood nitrous refill depot. They ran over 100 bottles of nitrous though that motor and bolted on a little 142 blower before they blew it up.. and this isn't no fishing story......
Now once they bolted on the 142 that little motor had all the power it needed without the nitrous, but hitting that switch made it soo much more fun...... :twisted:
Moral of the story.. Go easy on the nitrous, with proper a/f ratios your motor just might last a few extra passes..
Not bad for a couple young teenagers
Gm Steel Crank
clevite bearings
Ash you got any small block heads u wan to get rid of ?..looking for some heads for this procharger small block i am building...i just don't trust buying anything like this from someone far off i do not know....you know where i am coming from here.
i have dealt with Big Blocks for so long..i have Nothing but a few small block intakes laying around...
thanks Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
suicide,
This is what I refer to as a fish story.
[/img]
In no way did I consider your comment negative....
LOL 8)
No not at all, I was just speaking in general....
Matter of fact I find a lot of your postings quite humorous and usually can't wait to see what ya come up with next...
B Juice, Let me do a Little digging, I just might has something your looking for.
[/img]
Y'all gotta remember, the higher the compression, the higher octane fuel you wanna be running to help avoid detonation. My 632 is 14.5:1 comp. I run 700 hp nitrous through it and C16 fuel.
You'll probably want to run 100 octane or better, maybe C12.
Originally Posted by jreiley
Thanks to all for the info. One other question - any NOS vendor better than the rest for sbc applications?
This is a small block with a fogger with 2 stages and 2 plates. All total a little over 800hp of NOS on a small block!! :shock: It's UGLY when the bottle of whoop azz opens the wrong way!! About every 10-15 passes it gets new rings. Look under the front of the intake. It was a nightmare to plumb!! :x :x
#18
Originally Posted by bjuice
the WABBITT ON STEWIODS !!!!!! :shock: :shock:
That's not the Rabbit motor. It belongs to Randy Roberts. He gets on here every now and then. His profile name is gimmemud on RJ.
I do all the teching at our (MRA) races so I get a good up close look at what everybody's got!!
