1.428 60' time with 9.65 et is my 60' time slow?
Old 09-15-2009, 12:37 PM
  #41
itsabird
yep, on hitting the tires to hard, more air would help, if you have double adjustible shocks, try stiffening rebound, and softening compression a little, that is if you use that intersect point.
itsabird is offline
Old 09-21-2009, 01:36 PM
  #42
bowler
SENIOR BUILDER
Default et
i ran at madras sat. & sun., put the msd 6a in now my tach reads correct and the shift light works! set it at 6900 rpms, sat. temps in mid 80's with clouds air was 4500', ran [email protected] and [email protected]: [email protected]' and [email protected]; [email protected]' and [email protected], first round [email protected]' lifted; round 2 [email protected]' lifted; round 3 [email protected]' ran 6.465 @97 mph ! break out. sunday backed compression off 2 marks (rear shocks) weather was clear and cool [email protected]' [email protected]; and [email protected]' and [email protected]; and [email protected]' and [email protected]; round 1 red light [email protected]' and [email protected] ran both lanes with a small difference between them, i tried 7# air then went to 8# after first run (sat.) then went back to 7# for the rest of the race, it was a race both days so its hard to play with the air and shock settings. next race 2 weeks and i'am going to put a delay box in it and try s/pro. bowler
bowler is offline
Old 09-21-2009, 03:23 PM
  #43
itsabird
did you stiffen rebound? if not next time out, you may want to try that also.
itsabird is offline
Old 09-21-2009, 04:17 PM
  #44
TopspeedLowet
Default 2" off IC? no way on that roadster
Originally Posted by bowler
i ran my new car at woodburn 9-8-09 it ran 1.428 60' 3.993 @ 330 6.171 @ 1/8 at 112.95 mph, 8.056 @ 1000' 9.652 @ 1/4 mile with a speed of 139.42 and i lifted about 100' early my question is my 60' slow, my car is 2400# 109" w/b, strange struts (single adj.), rear susp. is 4 link with double adj. strange coilovers, 4 link intersect is about 50" out and 2" above ground, i have struts adjusted in the middle and the rear shocks are set in the middle on both compression & rebound. also the weight is close to 50-50 and my rear tires are hoosier 32.5x16.5x15 (co7) thanks for your help Bowler
If you have not yet resolved this cars behavior off the line yet, I recommend raising the IC at least 4" higher than it is now. If you are not guessing where the IC is, then that long wheel base and with a mouse power (I presume) will need a raised IC be able to plant your tires thru the 60' . If you know what your crank height is as well and it is much at all below 11" then you will have a hard time getting your car to hook with repetition at your power level and wheel base. Your car was likely set up for over 1000 HP with 2" off IC, the 50" is short for big power but a mile long with a setting at 2" off the ashephalt. If you raise the bottom bar one hole in the front and raise the front of the upper pipe at the same time this will raise the IC and make the 50" IC seem shorter to the car than it does now. Shortening may not be the best path with that long 108" WB. Work with the height first then the rebound on the shock to get control on the big end.
johnracer has a roadster with a shorter wheel base than yours and seems happy with his wally winning roadster after raising his ride height to raise the crank higher and raised his IC to get his to react better.
Bruce
TopspeedLowet is offline
Old 09-22-2009, 02:34 AM
  #45
johnracer
Default Re: 2" off IC? no way on that roadster
Bruce
Hey Bruce! Wassup? Thanks to you, yes I'm very happy with mine! Currently the car is WAAAY better than I am though. I need just a little luck.........you wouldn't believe how many times I've lost races by just a few thou this summer! Dang good racing, but the win lite keeps coming on in the wrong lane........good to hear from you
Johnny
johnracer is offline
Old 10-02-2009, 04:21 AM
  #46
johnracer
Hey Doug, is that your pic on pg 62 of the latest National Dragster? Very cool!! Congrats,
Johnny
Old 10-02-2009, 07:58 AM
  #47
TopspeedLowet
Default Page 62, YUP there is Doug
Wow Doug, aren't you something. Best engineered car award! That is great Doug. Johnny has a great eye doesn't he!
Good call John.
John, Doug is tightening the back spread to help his reaction like you did on yours. Doug is not scarred to change his 4 link and knows his car very well. I am confident he will have it right where the wants it to be soon, if he has not already. You both are a pleasure to talk to about chassis set ups because you both actually do them and don't just take opinion poles on changes.
Bruce
Old 10-04-2009, 06:14 PM
  #48
bowler
SENIOR BUILDER
Default et
Johnny thats me! thanks again Bruce raced, at madras this saturday cloudy and cold in the 40's they hot lapped us to try and beat the rain, (sunday rained out) i used a delay box for the second time ever first run let go of the button and nothing happens? i let off the gas oh crap nailed it had a .567 spun and ran [email protected] run 2 a .488 red ran [email protected] run 3 .560 ran [email protected] run 4 first round a nice .673! ran [email protected] round 2 .570 ran [email protected] fianlly ran someone that could cut a light and my day was over my 60' were (thru out the first one) 1.468, 1.421, 1.454, 1.457. with 6 1/2# air, just proves you can't teach old dogs new tricks! even with a delay box i can't cut a light i had a friend run it for t/o and he had a .518 light! i'am done for this year, but i will stay with the delay box also i'am going to sell the donovon block, oil pan & crank so i can build a 434" or a friend has a bbc fresh this year that dyno'ed at 825hp ran 920's @ 3400#. next year will be fun Bowler
bowler is offline
Old 10-05-2009, 02:18 AM
  #49
johnracer
Definately stick with the box. They're not magic and take time to get used to it. Personally, I think the bigblock would be the ticket. I've always run run smallblocks until I got my 522 and I probably won't go back. What a difference!! It just keeps on pullin!!
Congrats again,
Johnny
Old 05-31-2010, 02:23 PM
  #50
bowler
SENIOR BUILDER
Default 434"
just fired up my new motor last night, first time out will be Boise Idaho's oldies race June 5-6 this motor is a Dart block with a compustar 4" crank 6" h beam rods & JE pistons 58 cc AFR heads suspose to be 14.7 to 1 on gas, maybe i'll see those 1.30's @ 60'. bowler
bowler is offline
