pro/sportman brake red light green light
Old 06-25-2009, 07:24 PM
wrightway
SENIOR BUILDER
Originally Posted by johnracer
an additional hole is usually drilled in the rear of the case for a pro brake. I'm not sure if you'll have to plug it
I have the aluminum hipster brake and it is a double dump and the case is drilled in the rear
I have spare unmodified cases so that’s not a big deal
wrightway is offline
Old 06-25-2009, 07:29 PM
wrightway
SENIOR BUILDER
Originally Posted by shawnp
you need to adjust front tire psi, size
I have lowered the two step to 3100 any lower and it a inconsistent dog on the line
I have the tallest that will fit m/t sportsmen radials on front now not a lot of sidewall give in them
Had a set of e/t drag front before very adjustable sidewall still not enough
Old 06-25-2009, 07:32 PM
hammertime
Can you slow the hit down by changing the 4 link ?
hammertime is offline
Old 06-25-2009, 07:44 PM
wrightway
SENIOR BUILDER
Originally Posted by onedragracer
You might try one of the slow releasing transbrake switches from Biondo.
That might help you.
That’s one of the options I’m looking at but I kind of feel they may be an inconsistency waiting to happen
Hence the? About reaction difference going to a sportsman brake I feel and I may be wrong it's the more consistent answer to my problem
Old 06-25-2009, 07:46 PM
wrightway
SENIOR BUILDER
Man I wish I had a 4 link David but a ladder bar car :wink:
Old 06-25-2009, 08:00 PM
wrightway
SENIOR BUILDER
On a good note that fast reaction should work well on the arm drop at pinks all out in two weeks :lol:
Old 06-26-2009, 02:18 AM
johnracer
I've seen some really long throw buttons that some comp eliminator cars use. They look kinda goofy, but they work......
johnracer is offline
Old 07-06-2009, 03:12 PM
  #18
cartwright454
JOURNEYMAN
Hay Joe You could talk to the guy who built your trans and see if it can be fixed.
cartwright454 is offline
Old 07-08-2009, 03:55 PM
  #19
topfuelryan
I have the same problem in my FED with a pro brake. I was told that pro brakes react around .4 and bracket brakes around .5 which would be perfect for me since I am about -.105 at the first sight of third yellow.
This may sound stupid, but heard of Alan Johnson doing it to get around the rev limiters in top fuel when they came out. He ran an extensive amount of wire to lengthen out the time it took to travel from the rev limiter to the ignition. I have thought of taking a 25' coil of wire and splicing it between the button and the trans brake/two step. Any electrical guys thing that would work. Could you use lengths of wire to tune your reactions times. I don't believe it is against the rules. :roll:
topfuelryan is offline
Old 07-08-2009, 10:54 PM
  #20
suicidebomb
Sure that'll work, but electricty travels at the speed of light, so 18600 ft of wire should equal a tenth of a second. there is no rule against haveing that much wire in your car, but where will you set :P 25 ft, will make no difference.
suicidebomb is offline
