Ok...second trip to the track.....much better!!
Originally Posted by maydayneal
Originally Posted by bbchevy
#1 The Converter for that Combo is WAY To LOOSE!
I would think 4500-4800 would be Great?With around 3600-3880 Launch.
JMO...........
Later
G 8)
JMO...........
Later
G 8)
So would the additional weight (600#) make the converter loose like that??
Dang....sure would hate to have to invest in another converter right now....but sounds like your suggesting a move from the 8" to something in a 9" config??
I also got to tell ya guys that I'm sure I was short shifting into second gear....had the shift light at 6200....and I probably should move that up to some where around the 7000 range.
Call your Converter Guy,ask Him if he can Make your current Converter work with the COMBO you have Now?
Sometimes they can TIGHTEN a 8" up enough to Work?It MIGHT Not be the Best,but other that Buying a New Converter?He will be able to Point you in the CORRECT DIRECTION?Also,By Him cutting it open,they will be able to see whats,WHAT???
Later
G 8)
