How big of a carb????
Old 05-20-2009, 09:48 PM
  #21
dragonmaster093
old 305 had more power hell with same intake carb ignition on half drad 305 could boil hides not now has 255 75 15s on rear
dragonmaster093 is offline
Old 05-20-2009, 10:42 PM
  #22
Tod74
Originally Posted by dragonmaster093
gears stock cam real ruff idle 32 degrees i know it has torque and power dog off line but will haul ass
I would Bump the timing up to 36-38 deg.
Tod74 is offline
Old 05-20-2009, 11:53 PM
  #23
dragonmaster093
ill try that
Old 05-21-2009, 03:44 AM
  #24
kbartley
Default how big of a carb.???
Whitey, did you get youre carb situation straight? Kris
kbartley is offline
Old 05-22-2009, 09:40 PM
  #25
justin45
SENIOR BUILDER
go with a 700 holley
justin45 is offline
Old 05-26-2009, 02:51 PM
  #26
whitey70ss
Thanks for askin kris! I just got my oil leaks fixed and decided to put the victor jr intake on and a 750 dp . I havent got to tune the carb yet nor do I know enough about these double pumpers to mess with it. But for just throwing it on and setting the Idle it works very good. I have a slight dead spot just off idle but I dont know where to start looking.
whitey70ss is offline
Old 05-26-2009, 08:10 PM
  #27
kbartley
Default CARB
Check youre timing first. Get a vacuum gauge hook it to a full vac. port, set the mixture at idle looking at the gauge. Try it out, if that dont get it then its time to adjust the accelerator pump, NOT TOO MUCH AT ONE TIME. What type of distributer are you using? Keep us posted.
Kris
kbartley is offline
Old 05-26-2009, 08:19 PM
  #28
whitey70ss
msd pro billet distributor. When you say adjust the mixture per the gauge. What exactly am I looking for??
Old 05-26-2009, 09:45 PM
  #29
cepx111
Adjust the idle mixture screws (the small ones on the metering block) to achieve the highest vacuum.
Bump your timing up to at least 38
Getting some taller gears would be a big help too.
cepx111 is offline
Old 05-31-2009, 03:56 PM
  #30
whitey70ss
I have a vacuum brake bleeder with a gauge on it will this work?? As for the gears I want this to be a little more cruise friendly I have a nova with 4:11's and 25 in. tire not real cruise friendly. :lol: This chevelle has 3:73's and 26in. tire, seems to work well for all the more I've driven it.
