Any input on Predator carb's
Old 01-30-2009, 07:50 AM
dparker
I've seen few run. They're very responsive and have great bottom end. But in drag racing they seem to go flat at 1/2 track. I don't know if that can be fixed or not. Thats been with the 5 or 6 that I've seen used at the track.
This is Predators frequently asked questions. They also have a 21 page manuel you can print out thats very informative.
Frequently Asked Questions
How does the Predator work?
The Predator is a variable venturi design that works off of the air demand of the motor and meters fuel accordingly. Thus, provided that you have the proper fuel metering cam for your application, you will neither be undercarbureted or overcarbureted with the Predator at any given rpm range.
What kind of carburetor is the Predator suitable to replace?
The Predator replaces four barrel carburetor applications from 600 cfm to 930 cfm.
What is the Predator fuel metering cam?
The Predator fuel metering cam is a flat piece of brass located inside the fuel bowl that is cut to a certain slope. The slope of this cam is what determines the air/fuel ratio from roughly 3000rpm and up.
How easily can the throttle linkage be installed?
The 6000 is equipped with a simple throttle arm which has two 1/4" diameter holes in it for easy adjustment and quick installation.
What are the adjustments on the Predator?
The three simple adjustments are idle mixture, idle speed, and upper rpm metering cam change.
Is there an air cleaner adapter available?
A standard 5" o.d. air cleaner adapter is included with every purchase of the Predator 6000.
Are there any vacuum hose connections on the Predator?
No, there are no vacuum hose connections on the Predator.
How tall is it?
The Predator is 5 1/4" in height from the bottom of the base to the rim of the air cleaner adapter.
How does it work with nitrous oxide, blowers, and turbos?
The Predator is an excellent application when used in conjunction with nitrous oxide, on a blower, or with a turbo charger (draw though type).
How much fuel psi is required for "all-out" maximum performance?
On a naturally aspirated motor, 6 psi at wide open throttle is required for maximum performance
dparker is offline
Old 02-12-2009, 08:04 PM
oneowner73
JOURNEYMAN
Used to drive an old C/ED in bracket trim with a 316" sbc comp engine. We tried a Predator. The throttle response was so good that driving a hardtail dragster around in the pits and staging lanes was difficult. Every bump bounced your foot and made you look jerky. The results were that the car was still faster on the track with a 750 Holley than it was with the Predator.
Brian
oneowner73 is offline
Old 03-06-2009, 02:17 PM
stealth20
I wonder how they calculated the cfm...? at what depression?
stealth20 is offline
Old 03-25-2009, 06:54 PM
gonhntn2
my dad and uncle both ran them on there mud trucks and loved them some guys talked my uncle into putting a dominator on his truck one time and he got spanked so he threw it away and put his predator back on.
gonhntn2 is offline
