what trany do I have
Old 01-13-2009, 10:06 AM
desoto30
JUNIOR BUILDER
Originally Posted by TopspeedLowet
Originally Posted by desoto30
Originally Posted by Tod74
Originally Posted by chpseat987
Wow great stuff Thank you the trenny brake is on the pass side. I have a reular pan do you recomend a fin pan for cooling?
the deeper pan will hold more fluid so that alone will help with the heat.
I use the heavy cast aluminum pan on my glide ..it helps to stiffen up the case..at least I think so.
How does the deeper pan help with the heat?
Well, the more oil that you have in the system, the more heat that is will take to raise the temp.
& thereby increasing the time that it takes to reach operating & overheated temperatures.
desoto30 is offline
