How much stall??
Old 12-07-2008, 09:24 AM
dparker
SHOW OFF!! :wink:
dparker is offline
Old 12-18-2008, 03:25 AM
Drtmod5
I have to do this mostly myself in order to be able to afford it. So where do I look for good reasonable parts & a list of what I need would be appreciated. I've had alot of answers on this topic and they've been all over the place on the stuff I really need to upgrade. Thanks again for the help. Dave
Drtmod5 is offline
Old 12-18-2008, 10:16 AM
PTC, has some pretty good prices on any and everything you need, and they are good people to do business with, i have, and most of my friends have been running their converters for yrs.
http://www.ptcrace.com/
Old 12-22-2008, 02:50 AM
Drtmod5
If I was to put a brake in the TH350 I have now, would I need to change stall or gears that way? The trans I run has all good parts including an ultra bell but not a brake.
Drtmod5 is offline
Old 12-22-2008, 03:41 AM
us7race
Your Stall and gears would work fine. I am not so sure you willl hook though.. That 3 speed has alot lower 1st gear than say a glide...
us7race is offline
Old 12-22-2008, 08:17 AM
Drtmod5
Thanks Jody, I'm looking into just buying a glide if I can find one reasonable. After adding up the parts I need to do my own, the price will be about the same. So how's things with you, haven't seen anyone this year since my job has kept me from racing at all. Take care, if you come up with anything let me know. Thanks, Dave
Drtmod5 is offline
Old 12-22-2008, 09:42 AM
Tod74
My glide has a transbrake,good input shaft and a dual ring servo and the good clutches but I think the rest is just factory stuff..1.76 planets.
3200 lb big block car so far no issues knock on wood.
Tod74 is offline
Old 12-25-2008, 01:30 PM
  #18
Drtmod5
I have a good line on a glide I think I'll get, so if I change to the 5.29 gears what stall would I need then?
Drtmod5 is offline
Old 12-25-2008, 11:38 PM
  #19
If the motor will pull 7300/7500 rpm the 4.88 or 4.56 will work just fine for 1/4, as long as it won't run over 135mph. i run 5.43 but only run 125m mph and it crosses the line at 7300 rpm.
Old 12-26-2008, 04:04 AM
  #20
Drtmod5
1/8th mile is all I run
Drtmod5 is offline
