which line lock will hold back big tire chassis car?
Old 04-17-2009, 09:38 PM
sds10racer
are the front tires rolling or sliding? got a friend that thought his was rolling thru, i watched it on the line and saw that it was sliding the tires. had him drop his rpms on the footbrake and it quit sliding them. now he runs a transbrake 8) . wider fronts tend to not slide as much as there is more surface on the pavement.
sds10racer is offline
Old 05-14-2009, 02:08 AM
chevyfireball
I pump the shit out of the brake pedal and hit the line lock. As soon as the cars up on the tires I let off the line lock and smoke it on down the track.
chevyfireball is offline
Old 08-10-2009, 11:19 AM
timothysiler
APPRENTICE
Whats line lock? I just mat it and take it out to the 330' :wink:
timothysiler is offline
Old 08-10-2009, 05:27 PM
TS1955
I've seen some drivers "roll" into the throttle when doing a burn-out and they would slide the front tires. When I do a burn-out I hit the throttle hard and break the tires loose. It usually stays in the burn-out alot better! JMO
TS1955
TS1955 is offline
