Optima Batteries
Old 12-03-2008, 01:32 PM
BEAST477
BEAST477's Avatar
I'm running 2 NAPA orbital batteries in my car with alt after 5 yrs still going strong. Had a Turbo Start 16v before that what a piece of junk.JMO
BEAST477 is offline
Old 12-03-2008, 02:09 PM
sg1586
Originally Posted by russ67chevelle
ONE NOTE TO PASS TO FELLOW RACERS-BEST THING FOR YOUR REAR MOUNTED BATTERY SET UPS IS TO HAVE A GOOD HEAVY DUTY LINE FROM ALTERNATOR BACK TO THE POSITIVE ON BATT. I USED HEAVY 4 GAGE WELDING WIRE AND ABSOULUTELY NO PROBLEMS WITH 1 OPTIMA RED BATTERY AND POWERHOUSE 120 AMP ALT.IT WASNT HOLDING AS GOOD OF A CHARGE WITH SMALLER GAGE WIRE!!!!
One thing I don't like about this is that even with the master switch in the off position you still have 12 volts to that Alternator all the time :shock:
sg1586 is offline
Old 12-03-2008, 02:32 PM
fla1976
fla1976's Avatar
Default Alternator
You can get away from the constant source to the alternator by installing a relay that is activated by the master cutoff switch. That way there is no power with the switch off.
fla1976 is offline
Old 12-03-2008, 04:17 PM
sg1586
Default Re: Alternator
You have a part# for a relay that will take a #4 wire????
sg1586 is offline
Old 12-03-2008, 04:54 PM
fla1976
fla1976's Avatar
Default relay
Here are a few sites:
http://www.texasindustrialelectric.com/relays.asp
http://www.nextag.com/12-volt-contin...id/search-html
http://www.thewiringproject.co.uk/se...cal+%3E+Relays
http://www.neon-john.com/RV/Electric...ion_relays.htm
http://www.dedenbear.com/ACCESS_cat.htm
Hope these help.
fla1976 is offline
Old 12-04-2008, 03:08 AM
sg1586
Thanks!!!
sg1586 is offline
Old 01-23-2009, 09:57 PM
ashbros
If I got anything from reading this thread it is 2 batteries are better than 1
I run 2 batteries optima batteries myself
works great for me
never had a problem
ashbros is offline
Old 01-25-2009, 05:18 PM
  #18
superstreeter
SENIOR BUILDER
lots of good batteries out there now,,I do like the optima red and you need to get a real alternator if your going to run on the street, I`ve been screwing with batteries and alternators on my street car for years, and the best I`ve come up with is the red optima (because its lite)and a good 100 amp alternater, you have to find a way to run an alternator, sooner or later you will have a problem, and you wont be likeing it. just my oppinion ...I run a single red, and lots of fans and pumps, and it starts my bbc like nothing!
superstreeter is offline
Old 02-01-2009, 08:11 PM
  #19
RonOwensRacing
The best battery by far that iv ever owned is the Kinetik just one bad battery.
I now sell them i still sell optima also but these are catching on now .
RonOwensRacing is offline
Old 02-02-2009, 09:35 AM
  #20
dparker
I sure could use a battery sponsor!!!!!!lol.
dparker is offline
