Fuel pressure problem
Old 08-07-2008, 01:30 PM
  #21
mopar1968
mopar1968's Avatar
The gauge location has been the same since the car was built.
mopar1968 is offline
Old 08-10-2008, 05:21 PM
  #22
Scooterz
Mopar: any luck yet? I have not been on Rj for almost a week....
Scooterz is offline
Old 08-10-2008, 07:40 PM
  #23
mopar1968
mopar1968's Avatar
Well maybe i talked with Ron Owens on the phone and the only thing he could come up with is maybe either the pressure spring in the pump is broken or the pressure valve is stuck in the pump, causing it to pump full pressure and over come the regulator, he is sending me a pump to try and see if it cures this problem. I want to thank all you guy's for your input and help! thanks again. Mark
Old 08-13-2008, 04:44 PM
  #24
mopar1968
mopar1968's Avatar
Just to let everyone know Ron Owens hit the nail on the head, installed fuel pump he sent and fuel pressure problem solved, Thank everyone for your help. Mark
Old 08-23-2008, 12:54 PM
  #25
dparker
Default fuel pressure
Not to say your gauges aren't accurate but I've never seen any needle seats that could withstain 15lb of pressure with out bleeding over. Maybe your reading gauge pressure before regulator, or one or both gauges are reading inaccuratly.
dparker is offline
Old 08-23-2008, 09:07 PM
  #26
fla1976
fla1976's Avatar
Default Carb
Sounds like you need a bumper sticker "RESCUED BY RON". It's nice to have a parts supplier that is also a thinker.
fla1976 is offline
Old 08-25-2008, 09:36 AM
  #27
mopar1968
mopar1968's Avatar
You got that right, if i had a sticker you bet it would be on my car, has helped me more than once. :!: :!:
Old 01-16-2009, 07:42 AM
  #28
dparker
Hey Mopar what was the problem with the 15psi? Did you get it fixed?
dparker is offline
Old 01-17-2009, 01:41 PM
  #29
mopar1968
mopar1968's Avatar
Yes got it fixed thanks to Ron Owens, the pump was stuck wide open, relief valve wasn't working. got a pump from Ron everything back to normal.
