flashing around spark plug boot
Old 08-04-2008, 03:18 PM
hkfs72
I called MSD today and they said it was normal. I borrowed some moroso 40 wires and still the same. Changed from autolites to ngk and cleaned up grounds on both heads , block and frame new rotor and cap and still the same. I'm not going to pull my hair out , but just trying to figure out what is causing this. BTW the plugs are gapped at 35. Thanks for the replies.
hkfs72 is offline
Old 08-05-2008, 03:14 PM
olds48
If it's flashing it's leaking,bud.need to figure out how to keep that energy from escaping.You want that electricity arcing in your cylinders,not under your hood
olds48 is offline
