Starting Issues
Old 07-28-2008, 04:54 AM
  #31
duswill
I had the same problem. I installed a MSD Digital 6 and and to date have not had the problem again.
duswill is offline
Old 11-11-2010, 05:08 PM
  #32
482
Hammertime, just wondering if your problem ever recurred or did the starter fix it permanently ? Mine appears to be doing the same thing while restarting.
It will spin like crazy until I hit the ignition switch then starts to drag.
(Also a Tilton starter)
Thanks
482 is offline
Old 11-12-2010, 04:13 AM
  #33
hammertime
I've never had a problem sense, I had my tilton gone through again at local starter shop, put it back on and it works ok now, he changed a few things in there. I still say it dont work as good as my cheap starter I got from him.
Check for voltage drop first and once you rule out voltage is not a issue look at the starter.
hammertime is offline
Old 11-12-2010, 02:34 PM
  #34
482
Cool ! Thanks
I will check the voltage.
Do you still have a drop in voltage going back
To starter?
One last question, did you end up wiring in the
Starter saver too?
482 is offline
Old 11-12-2010, 07:25 PM
  #35
hammertime
I do have voltage drop but not much. Your looking for a major drop while cranking, ign on and off back there. I ended up buying a digital ignition and pulling 8 degrees out also. Starter saver would work also, i've used them in the past.
Old 11-14-2010, 05:07 PM
  #36
482
thanks David !
Got a starter saver on the way. 8)
482 is offline
