Need help on BBC alcohol tune.ROOKIES
Old 06-08-2008, 03:36 PM
hammertime
Originally Posted by OneBadGMC
You realize that the leak down is just a base, and that you'll have to change it 2-3 times every day, right?
Start the motor, loosen the screws, fatten it up until it surges, then lean it back out just until the surging stops.
As for plumbing.... See below.
I've got to ask why change it 2-3 times a day ??
Once you get it set the only change you should make all year is a pill change from hot to cold or cold to hot weather ??
I run return straight to top of fuel cell, crank trigger MSD.
hammertime is offline
Old 06-08-2008, 06:03 PM
OneBadGMC
Barrel valve leak changes with the weather, just like the main pill does.
I take it you don't own a weather station.
OneBadGMC is offline
Old 06-08-2008, 06:43 PM
hammertime
I do .. mine stuff doesnt get changed at all, all year. Toilet or Terminator must be I am just lucky. I know NO one who changes the BV once they get it set where the car likes it. I dont even change the pill in my setup its good either way. Spring Weather to Hot Summer weather no change 7.55 in spring 7.55 in hot guess I got lucky.
Old 06-08-2008, 07:10 PM
OneBadGMC
Rather be lucky than good anyday.
Old 06-08-2008, 07:13 PM
hammertime
ahmen to that :lol:
Old 06-09-2008, 03:15 AM
us7race
What do you know on a High Speed Lean-out? :wink:
us7race is offline
Old 06-09-2008, 08:43 AM
OneBadGMC
I know if you don't set it right, you can plan on buying new pistons. :wink:
Do you have a more specific question?
Old 06-09-2008, 08:21 PM
  #18
us7race
My buddy has just added one and I figured I'd ask. He is going to start out with the smallest pill and go from there. His EGT's on a couple of cylinders were down to around 300 still ran 6.52 @209 in the 1/4.
I think it was a 4.19 in the 1/8 on a not the greatest track..his 60' was off from .980's to 1.0's. so Hopefully with more seat-time in the car and the high speed lean-out can go 6.40's or better..
us7race is offline
Old 06-09-2008, 10:44 PM
  #19
OneBadGMC
Try this site: http://dragracemath.jimhatleyracing.com/fuelsys.html
Should help him setup the high speed if he knows what he's looking at.
Old 06-11-2008, 09:32 AM
  #20
OneBadGMC
Just because I thought of it... Aren't you running a normally aspirated motor?
