HOW LONG SHOULD THE TRANSBRAKE BE ON???????????
Old 08-26-2008, 04:28 PM
hammertime
Default Re: HOW LONG SHOULD THE TRANSBRAKE BE ON???????????
Originally Posted by jrthone
I have 632BBC 1.76 Powerglide 4500 stall 8" converter and 4.88 9". What pill should i run in my 2 step for the transbrake launch for the 4500 stall converter.Can i Run a 4400???? How long can i rev the motor on this RPM limiter on the line(2-3 secs???)Before the light goes green.In other words when shoul i plant it(maybe as late as possible to save trans life).Or should i run a lower rpm pill for my launch on the 4500 converter.Any advise will be much appreciated.
Buy a starting line enhancer !! Best money you'll ever spend when being a fast car
hammertime is offline
Old 08-26-2008, 06:36 PM
us7race
Originally Posted by ARUSSELL
One thing to be careful about is it does not matter when on the brake if there is a cooler or deep pan, when on the brake the fluid is not being pumped, hence such the high temps created. Now the cooler and the deep pan will cool the fluid quicker when making the run.
What do you mean the fluid is no being pumped?
Wouldn't it have to be to hold in gear? :?:
us7race is offline
Old 08-27-2008, 05:36 AM
olds48
As long as the converter/flexplate is spinning,the front pump is spinning.If the motor is on,the fluid is pumping.
olds48 is offline
Old 08-27-2008, 06:30 AM
ARUSSELL
Fluid is locked in the valve body and what is in the converter stays and nothing is traveling through the cooling lines. Sorry if I made it unclear.
ARUSSELL is offline
Old 08-27-2008, 10:19 AM
Racefab57
What's this stating line enhancer??? David.
Racefab57 is offline
Old 08-27-2008, 10:49 AM
curtisreed
curtisreed's Avatar
Curtis
curtisreed is offline
Old 08-27-2008, 07:34 PM
hammertime
As pictures shown about is what it is
It hooks up to your throttle pedal or up at the end of the cable on the carb. You let go of the transbrake button and it automatically brings it to full throttle when you have it set to come on is upto you. Depending on the type the pedal could go to the floor with force from it or it could just fall to the floor with no pressure.
Old 09-03-2008, 01:33 PM
  #18
sc4405
JUNIOR BUILDER
Default sle
Hammertime forgot to add that it's controlled through your delay box, most have an SLE function with adjustable time for the throttle to go WOT before brake release. I have run mine at .8 and at 1 sec. before release. You light the second bulb on the mat and the box does the rest - slicker'n snot! 8) JB
sc4405 is offline
Old 09-14-2008, 01:22 PM
  #19
dparker
Hey Jim, when you going to bring that new car out? Your old car just kept on winning after you sold it. All that time I thought it was you that was so good. Hummm maybe it was the car.
Not Really, it was good to see you out helping the guys this weekend.
take care,
dparker is offline
